Trojan Boats
5200/6500 BTU
9000/12000 BTU
16500 BTU
Misc Cooling
MARINE AIR CONDITIONING
5200 BTU - Air Conditioner
M5 - 5,200 BTU
Designed for boats up to 26 feet, or to cool sleeping compartments on larger boats. Approximately 450 cubic feet
COOL ONLY UNIT: L-15" W-11.5" H-11.5
REVERSE CYCLE UNIT:  L-18" W-12" H-11.5"
Smallest footprint on the market and weighs in at 31.5 lbs. for the unit, and 4.7 lbs for the electrical box! This unit has a rotatable blower and tapers down to a "V" shape for those odd angle discharge installations.  We use 4” ducting and recommend a minimum of 2, 4” round supply grills with this installation.  This unit will run off the new Honda eu1000i 1,000 watt portable generator, while in cool mode.  Another option is to use a Statpower 1,000 Watt Inverter and 400 amp hours of battery power and you can anchor out (one average) for one night.  Due to the construction of this unit, electric heat is not an option with this unit. This unit is ideal for the "tight fit" installations and is a welcomed addition to larger vessels for individual climate controlled cabins.
Running amperage:  Cool = 4.4amps, R/C = 5.5amps.  Add one amp for the standard seawater pump.   Start up amperage is calculated by running amperage multiplied by 1.8.
On average, This unit is designed to cool cruisers up to 26' and sailboats up to 28'.
M-5C Cool only:  List - $1,045.   Our Price - $945.
M-5CHP Reverse Cycle: $ 1,195.   Our Price - $1,095.
*Above models include a programmable digital thermostat.
** Water pump sold seperately.
A complete installation kit including Footscoop, seacock, water strainer, dual ducting kit, and electrical connection kit is an additional $212.90
The Inverter kit and batteries are optional.
6500 BTU - Air Conditioner
M6 - 6,500 BTU
Designed to cool 550 cubic feet.
Unit Measures: L-16" W-11.5" H-11.5"
(Left and Top Discharge, add 1" in length)
This unit is available in right, left or top air discharge configurations, and is now available as a cool reverse cycle heat unit., We use 4” ducting and recommend a minimum of 2, 4” round supply grills with this installation. More is always better! This unit will run off the new Honda eu1000i 1,000 watt portable generator, while in cool mode. Another option is to use a Statpower 1,000 Watt Inverter and 450 amp hours of battery power and you can anchor out (on average) for one night. The electric heat option generates 5,640 BTU of heat. Electric heat option is not available in 220/240 Volt configurations.
Running amperage:  Cool = 6.4amps, E/H = 17.5amps, R/C = 7.5amps.  Add one amp for the standard seawater pump.   Start up amperage is calculated by running amperage multiplied by 1.8.
On average, This unit is designed to cool cruisers up to 27' and up to 30' sailboats. Left Discharge Shown.
M-6C Cool only:
List - $1,125. Our Price - $1,025.
M-6CEH Electric Heat: List - $1,175.   Our Price - $1,075.
M-6CHP Reverse Cycle: List - $1,230. Our Price - $1,130.00
MERMAID MODEL M5(5,200BTU) / M-6 (6,500 BTU)
INSTALLATION KIT
Trojan Boat News
TROJAN BOAT
EVENTS
If you have any upcoming Trojan Boat events please send them to:
Trojan_info@trojanboats.net
and we will post the information here.
Products for Sale
For a Free Catalog of Trojan Boat Parts use the Online Catalog Request Form
Also check out Beacon Marine Supply for all kinds of marine parts and supplies at wholesale prices @  BeaconMarineSupply.com
Trojan Inventory
If the Trojan part is available we have it. We can display and promote only a fraction of the parts we have for Trojan boats.
Beacon Marine Supply:
1-215-547-8853
Trojan Home Page ]    [ Trojan Boat Forums ]    [ Feedback ]
Copyright © 2008 Trojanboats.Net All rights reserved.
Webadmin@trojanboats.net
