 | Inflatable Boat
Sealant Kit Stops Slow Leaks! |
 | Liquid Rubber for
Re-skinning Inflatable Boats |
 | NEW! IMPROVED!
Topside Paint MAKES YOUR BOAT LOOK LIKE NEW AGAIN!
OFFBOARD™ Call Bob Prices
1-215-547-8853 A spring-loaded device created to lock onto
your mooring lines to keep the critters off board.
e-Marine, Inc Cooling to Remove Heat From Food ---
Marine Refrigerators And Boxes - Call for
prices
Smith
& Co. The modern technology that
restores deteriorated wood was invented in 1972 and is now an
accomplished fact. Routinely applied since 1972, around the
world from Kwajalein in the South Pacific to
Scandinavia, this technology grew under the administration of
its American inventor Steve Smith, physicist and chemist, to
span a range of products and related
applications
WEST SYSTEM epoxy is a high-quality, two-part epoxy
formulated and manufactured by Gougeon Brothers, Inc. It bonds
to fiberglass, wood, metal, fabrics, and other composite
materials and is easily modified for a wide range of coating
and adhesive applications. It is used for construction and
repairs requiring superior moisture resistance and
high-strength, and is especially suited for marine
applications. Epoxy resin is one of the most valuable tools
available for modern boat repair and construction. Its
popularity is due in large part to its versatility--it can be
used for making small repairs as well as cold-molding a brand
new hull. The nature of the material allows you to create a
mixture with the precise characteristics that you need. The
basic ingredient for all epoxy compounds is the epoxy resin. By
using a simple cookbook approach and measuring carefully, you
can tailor both the handling characteristics and the physical
properties of the cured resin. To achieve the proper ratios
(resin/hardener) we offer calibrated pumps to deliver the
correct proportions. Fillers are designed to thicken the epoxy
mixture. Use a High Density filler for strength and bulk. And
use a Low Density filler for cosmetic or an easily sandable
compound. Fiberglass cloth and other reinforcement materials are
often used in conjunction with the epoxy to provide additional
strength. West System105B .98 Gal Resin
$57.17 205B Hardener for 105 B $23.17
The best penetrating epoxy sealer made.
This is a product that should be used on any wood or plywood.
We have been using this product on all or wooden boat
projects. This product will be your best friend on any wood
work. Fixes rotten wood and soft wood. 100% better then Git-Rot
at 1/5 the cost .This modern technology that restores
accomplished fact. Routinely applied since then, this
technology grew under the administration of its American
inventor Steve Smith, physicist and chemist, to span a range
of products and related applications. The original Clear
Penetrating Epoxy Sealer™ was developed for restoration of
deteriorated wood. These products are now available at
Beacon Marine Supply.
2 Pint Kit Muliprime Sealer $36.002
2 Quart kit of Git-Rot will cost you $63.63
Quart Kit Multiprime $50.002
Gal Kit Multiprime $161.00 |
PlasTEAK Looks and feels like
real teak - Extremely non-slip wet or dry - Can be power washed - No Maintenance
- Environmentally friendly - Stain resistant - Fully UV
stabilized - Installs without screws
PlasDECK A guide to laying PlasDECK - Index of pages
intended as a guide only. If you find an easier or better way
of installing PlasDECK, by all
means, go for it and let us
know.
Marine Plywood and Teak Plywood call for pricing |
Call Bob Prices
1-215-547-8853 | |
Trojan Boat News
TROJAN BOAT EVENTS
If you have any upcoming Trojan Boat events please
send them to:
Trojan_info@trojanboats.net
and we will post the information here. |
Trojan Inventory |
If the Trojan part
is available we have it. We can display and promote only a fraction of the parts
we have for Trojan boats.
Beacon Marine Supply:
1-215-547-8853 |
