Trojan Boats
TB Search Page
TB Parts
TB Engines & Heads
TB Transmissions
TB Mufflers
Air Conditioning
Pier Cushions
TB Literature
TB Catalogs
TB Used Parts
TB Forums
TB History
TB Info Posting
TB Pictures
Trojan Boats For Sale
Boating Resources
TB Feedback
   TB Mufflers
 Westerbeke Marine Parts
Mufflers
PART # DESCRIPTION BEACON
MARINE PRICE
LIST
VT WLOCKL50R LP50 MUFFLER $51.15
JHW 34936 HYDRO- HUSH C RUBBER 1 7/8" END IN-END OUT $44.50 $166.00
MM-ST2000609 2" FIBERGLASS (SIDE IN-TOP OUT) $106.51 $123.58
VL 1500008 2" FIBERGLASS (TOP IN-TOP OUT) $103.97 $119.95
EL-MARK O 2" RUBBER MUFFLER, IN LIME $121.50 $145.00
VL 1500025 2" FIBERGLASS (SIDE IN-TOP OUT) $93.64 $119.49
*CUSTOM MUFFLERS TO MEET ANY POWER
NEEDS-CONSULT BEACON MARINE SALES DEPT.
(ELASTOMUFFLE, VERNAY, SALISBURY, MARINE MUFFLER.
EXHAUST FITTING AND ELBOWS
PART # DESCRIPTION BEACON MARINE
PRICE
LIST
AC 20047-2 2" CHROME EXHAUST OUTLET (4.5KW-20KW) $51.15
JHW-37816 1 7/8" TO 2" BUSHING $4.00
JHW-33340 STRAIGHT HOSE CONNECTOR 2" (FOR 34936 MUFFLER) $8.00
JHW-33341 45 HOSE CONNECTOR $8.00
JHW-33342 90 HOSE CONNECTOR $8.00
JHW-33943 HOSE COUPLING & CLAMPS $25.00
JHW-36680 ADAPTER 1 7/8" TO 2" $10.00
JHW-33327 ANTI-SIPHON VALVE $16.00
JHW-33327-2 1" T-FITTING FOR ANTI-SIPHON (JHW-33327-1=3/4") $5.85
JHW-CF-253-2 2" NYLON EXHAUST OUTLET W/ LOCKNUT $25.66
VT AIRTENTV ANTI-SIPHON VALVE, 1/2", 3/4", 1", 1 1/4" $45.98
* ADAPTERS, REDUCERS, & EXHAUST OUTLET FOR
ANY APPLICATION - CONSULT MMD SALES DEPT.
THRU-HULL INLETS
PART # DESCRIPTION BEACON MARINE PRICE LIST
BAASC-75LP 3/4" SEA COCK $31.90
BATH-75 3/4" THRU-HULL W/ NUT $11.80
BAHN-75 3/4" TAILPIECE $4.05
BAASC-100LP 1" SEA COCK $51.20
BATH-100 1" THRU-HULL W/ NUT $15.20
BAHN-100 1" TAILPIECE $6.20
FT1463/8x1/8 90* FUEL FITTING $9.50
FT139-3/8x1/8 FUEL FITTING $1.50
B-50-512-020 3/4 NPT X 1" TAILPIECE $7.40
B-50-512-019 3/4 NPT X 3/4" HOSE TAILPIECE $5.80
** MANY OTHER SIZES AVAILABLE
SEA WATER STRAINERS
SH18005CP 1" SHERWOOD INLET & OUTLET $42.55
SH18001CP 3/4" SHERWOOD INLET & OUTLET $24.47
SH14240 MOUNTING BRACKET FOR SH18001CP STRAINER $11.44
SH 14239 MOUNTING BRACKET FOR SH18005CP STRAINER $12.23
SH AP 3/4" HOSE ARB FITTING FOR SH18001CP STRAINER $1.84
SH AP 1" HOSE BARB FITTING FOR SH18005CP STRAINER $3.50
SHAP 3/4" X 90* 90* HOSE BARB FITTING FOR SH18001CP STRAINER $3.00
GO ARG 1000 1" GROCO BRASS INLET & OUTLET $128.66 $144.88
SHAP 1" X 90* 90* HOSE BARB FITTING FOR SH18005CP STRAINER $3.00
PER 493-005 PLB PERKO 3/4" SEA STRAINER $83.03 $104.33
** ADDITIONAL STRAINERS FOR ANY SIZE INLET & OUTLET, CONSULT BEACON MARINE SUPPLY SALES DEPT.
PANELS, HARNESS, SWITCH, SENDERS
JHW-43912-1 REMOTE PANEL (BCGTC MODELS & BCGB) $80.00
JHW-43914-34' REMOTE PANEL PLUG IN HARNESS (BCGTC & BCGB) $45.00
JHW-42610 REMOTE START/STOP (BCTGE MODELS) $98.00
JHW-33703 REMOTE START/STOP (4 CYL MODELS ONLY) $169.00
JHW-33703-1 REMOTE START/STOP W/ HOUR METER (4 CYL MODELS ONLY) $125.00
JHW--36055 OPTIONAL INSTRUMENT PANEL (4 CYL MODELS ONLY) $388.80
JHW-33703-15' GAS PANEL WIRE HARNESS (4 CYL ONLY) $19.50
JHW-33703-35' GAS PANEL WIRE HARNESS (4 CYL ONLY) $84.44
JHW-33703-45' GAS WIRE HARNESS (4 CYL ONLY) $175.00
JHW-33703-50' GAS WIRE HARNESS (4 CYL ONLY) $187.50
JHW-24943 REMOTE START/STOP (DIESEL GEN. SET) $65.00
JHW-36539 COMP. INST. PANEL-DUAL INSTALL. $257.60
JHW-30760 15' INST. PANEL EXT. HARNESS (DIESEL GEN. & ENG.) $47.00
JHW-22126 DUAL STATION SENDER KIT (24975 & 22124) $140.00
JHW-6-3 MARINE APPROVED TRI-PLEX (#6 WIRE AC) $4.82
JHW-8-3 MARINE APPROVED TRI-PLEX (#8 WIRE AC) $2.55
JHW-35303 CONTROL BOX COVER DIESEL GEN. 'S $13.00
JHW-35275 CONTROL PANEL COVER W/START/STOP/PREHEAT (DIESEL) $153.00
JHW-32008 SHIP/SHORE SWITCH 3-4, 5KW-2 WIRE (120V) DUAL SHORE CORD $164.00
JHW--32008-2 SINGLE SHORE CORD - 120V ONLY - 4.5 & 5.0 KW $103.86
JHW-32009 SHIP/SHORE SWITCH 6-8KW-2 WIRE (120V) & 11-15KW WIRE (240VO - DUAL SHORE CORD) $223.60
JHW-32009-2 SINGLE SHORE CORD 120V ONLY 6KW-8KW $133.76
JHW-32010 SHIP/SHORE SWITCH 11-15KW-2 WIRE (120V) & 20KW-3 WIRE (240V-OEM $361.20
R-3/4" WIRE REINFORCED INTAKE HOSE $6.57
R-1" WIRE REINFORCED INTAKE HOSE $6.90
R-2" WIRE REINFORCED EXHAUST HOSE $11.58
R225-036 2" HOSE CLAMP ( STAINLESS STEEL) $1.45
R255-016 3/4 & 1" HOSE CLAMP (STAINLESS STEEL) $1.32
GAS AND DIESEL FUEL AND FILTER
S 18-7852 GASOLINE - FUEL/WATER SEPARATOR - FILTER ASSY. $32.25
RA-025-RAC-02 GAS FUEL FILTER $35.65
S 18-8074 STRAIGHT FUEL FILTER FITTING $1.78
S 18-8067 90* FUEL FILTER FITTING $3.98
DAHL 65 DIESEL $142.42
DAHL 100M DIESEL $179.94
DAHL 200M DIESEL $289.30
RACOR 500MA-10 DIESEL $167.80
RACOR 220R DIESEL $104.48
RACOR 110A GAS OR DIESEL $79.00
RACOR 320RMER02 GAS FUEL FILTER ASSY. $69.95
CRU-23532 ELECTRIC ANTI-SIPHON VALVE $114.45
TP-479 ASV FUEL SIPHON VALVE 1/4 NPTX 3/8 BARB $9.30
TP-478 FUEL SIPHON VALVE 1/4 NPTX 1/4 BARB $9.30
SOUND GUARD ENCLOSURES
43132 SOUND GUARD 5.0 BCDB & 7.6 BTD $1,188.75
43354 SOUND GUARD 8.0 BTDA & 10 BTD $1,188.75
43372 SOUND GUARD 11.0 BTD, 12.5 BTDB, 15.0 BTDC $1,588.00
43535 SOUND GUARD 20.0 BEDA, 25.0 BED, 32 BEDA $1,864.00
44375 SOUND GUARD 4.5, 7.2, 9.6 BCGT, 3600 RPM $850.00
Please Note:
While every attempt is made to ensure the information on this site is accurate, this data is provided for information purposes only and is subject to change without notice.
Trojan Boat News
TROJAN BOAT
EVENTS
If you have any upcoming Trojan Boat events please send them to:
Trojan_info@trojanboats.net
and we will post the information here.
Products for Sale
For a Free Catalog of Trojan Boat Parts use the Online Catalog Request Form
Also check out Beacon Marine Supply for all kinds of marine parts and supplies at wholesale prices @  BeaconMarineSupply.com
Trojan Inventory
If the Trojan part is available we have it. We can display and promote only a fraction of the parts we have for Trojan boats.
Beacon Marine Supply:
1-215-547-8853
Trojan Home Page ]    [ Trojan Boat Forums ]    [ Feedback ]
Copyright © 2008 Trojanboats.Net All rights reserved.
Webadmin@trojanboats.net
