Trojan Boats
TB Search Page
TB Parts
TB Engines & Heads
TB Transmissions
TB Mufflers
Air Conditioning
Pier Cushions
TB Literature
TB Catalogs
TB Used Parts
TB Forums
TB History
TB Info Posting
TB Pictures
Trojan Boats For Sale
Boating Resources
TB Feedback
TB Engines & Heads
FIRST MATE MARINE ENGINES: At First Mate Marine, your complete satisfaction is our first and foremost concern. We offer short block assemblies with tin ware. If you need an engine that is not listed in our catalogue, please call us for a quote. Cylinder head, block and crank casting numbers will assist us in supplying your exact needs. First Mate Marine recommends priming all engines with a pressure pre-oiler. Please inspect all engines before signing the freight bill. If there is freight damage, we need to start a claim with the freight line.
Any questions call: 1-888-559-3555
Long Block Features 24 Month Limited Warranty / New Pistons, Moly Rings / Marine Cam and Lifters / Brass Block Plugs / New Rod, Main and Cam Bearings / New H.D. Timing Chain and Gears / New Oil Pump / New Marine Gasket Set / Block Resurfaced, Bored and Honed / Crankshaft Reconditioned / Connecting Rods Reconditioned / Valve Guides Reconditioned / Heads Resurfaced / New Valve Springs / Three-Angle Valve Job / Spin Tested / Pressure Tested Short Block Features 12 Month Limited Warranty / New Pistons, Moly Rings / Marine Cam / Brass Block Plugs / New Rod, Main and Cam Bearings / New H.D. Timing Chain and Gears / New Oil Pump / New Marine Gasket Set / Block Resurfaced, Bored and Honed / Crankshaft Reconditioned / Connecting Rods Reconditioned / Spin Tested
Head Kits New Valve Springs / Three Angle Valve Job
                       Warranty Information
FIRST MATE MARINE HEAD'S PRICE LIST by Manufacturer
Ford
General Motors
Chrysler
Mercruiser
FIRST MATE MARINE ENGINE'S PRICE LIST
by Manufacturer
Ford
General Motors
110 to 230 - 260 to 360 Hp
Chrysler
Mercruiser
Chrysler Engine Parts
Engine cooling systems. Change your raw water cooling system to a closed system. We have them for any motor call for price. Gm, Crusader, Merc, Volvo, Chrysler, Ford
Oil Coolers and transmission coolers. Two year warranty. Come standard with the most popular size bib 1 1/4" other bib diameters are available upon request. All oil coolers come with 3/8" NPT fittings,
2 piece rear main seal GM Motor double click for larger image
1 peace rear main seal GM Motor double click for larger image
Trojan Boat News
TROJAN BOAT
EVENTS
If you have any upcoming Trojan Boat events please send them to:
Trojan_info@trojanboats.net
and we will post the information here.
Products for Sale
For a Free Catalog of Trojan Boat Parts use the Online Catalog Request Form
Also check out Beacon Marine Supply for all kinds of marine parts and supplies at wholesale prices @  BeaconMarineSupply.com
Trojan Inventory
If the Trojan part is available we have it. We can display and promote only a fraction of the parts we have for Trojan boats.
Beacon Marine Supply:
1-215-547-8853
Trojan Home Page ]    [ Trojan Boat Forums ]    [ Feedback ]
Copyright © 2008 Trojanboats.Net All rights reserved.
Webadmin@trojanboats.net
