Chrysler
Parts and Prices
Chrysler
Parts and Prices, Manuals, Crusader, Dana, Hurst, Marine
Power, OMC, Sierra, Volvo, Aqua,
DAHL Filters |
Chrysler
440 Thermostat 160 degree comes with gasket
$55.00 |
Manifolds Ford 302 $262.00 - Chrysler
318 $194.00
We have manifolds, Riser and
related parts for all
Trojan Motors or any Marine Engine |
Camshafts used on CCW Right Hand Rotation
LM 318 and M360 Engines
P/N 3675870 $300.00
CW left hand Rotation LM318 M360
P/N 3675869 $240.00 |
Timing Chain Covers 6 styles - LM318 M360 M440
1968—present $102.00—$250.00
We also have all the Spacer's Pulleys, Gears, Timing chains , Timing
Indicators |
DRIVE GEARS Used on Right Hand Rotation LM 318 and M360 P/N 0007730E
$125.00
Used on Left Hand LM 318 and 360 Engines P/N 4723008 $93.00 |
Sherwood D– 55 $440.00 - Sherwood D 60 439.20
We have all the parts for rebuild as well
Sherwood SH G7 $225.00 |
Circulating water pumps, gaskets for
LM 318,M360 M340, M440,M383,M400 -
Water pump housings & thermostats all models
all years Thermostat housing
P/N 2846215 - $75.00
Thermostat housing kit - P/N 2846215K - $142.00 |
Thermostat used in 1975-1985 all V8 Models
with Carter Carburetors
P/N 3527765 140 deg
P/N 3514177 160 deg
$13.75 |
Thermostat
used in 1986 to Present -
All model V8 with Rochester Carburetor
P/N 4142885 140 Deg
P/N 4142886 160 Deg
$10.80 |
Water Distribution Tubes
1x1x1x1 1/2
P/N 0007098E -
$58.00
P/N 008545S -
1 1/2 x1 x 1 1/4 x 1 -
$63.00 |
Closed system cooling
LM318, M340,M360 1975-1985
P/N 3675141 -
$787.50 |
Side Mounted Heat Exchanger Used on LM 318
P/N 2847886
$407.00 |
Exhaust Manifold 1968—1985
LM318, M340, M360
P/N 41423221
$165.00 |
Valve Cover Used on Big block
Engines ( 2 holes )
P/N 3619872R
$49.42 each
Valve Cover GasketLM 318 M340 M360 Engines P/N 4095088 $26.33
We have Risers, Elbows, Extensions, End Plates, Manifold
Gaskets, O- rings, Sleeves |
Used on 1975 M383, M400, M440 - P/N 007081E
$195.00 |
Used 1986 to Present LM 318, M340, M360 - P/N 4417590
$320.00 |
Hydraulic Lifter Used on
LM 318 M340
M360 Engines P/N 4049338 - $9.62 each
Push rod used on
LM 318 M340 M360 Engines P/N 409591$8.22 each |
Remanufactured Cylinder Heads for LM 318 M340 M360 M440Part
Number: 4492073
Call for Price |
Check out Beacon Marine Supply for all kinds
of marine parts and supplies at whole sale prices
Beaconmarinesupply.com |
Trojan Boat News... |
TROJAN BOAT
EVENTS
If you have any upcoming Trojan Boat events please
send them to:
TBinfopage@trojanboats.net
and we will post the info here. |
Products for Sale... |
For a Free Catalog of
Trojan Boat Parts
or a Emperor Tackle "For Serious
Fisherman"
use the
Online Catalog Request Form
Also check out
Beacon Marine Supply for all kinds of marine parts and supplies at
wholesale prices @
Trojan Boat Sale Items |
If the Trojan part
is available we have it. This web site has only a small number of all
the parts we have for Trojan boats.
Beacon Marine Supply At:
1-888-559-3555 |
