110V AC
Posted: Mon Jul 31, 2017 10:33 pm
by lunkerbasserfishing
Wire recommendation for 110V outlets on 76 F26 ?
Re: 110V AC
Posted: Mon Jul 31, 2017 10:54 pm
by RWS
must be STRANDED not solid
Re: 110V AC
Posted: Tue Aug 01, 2017 6:52 am
by Big D
14/2 plus ground, stranded
Re: 110V AC
Posted: Tue Aug 01, 2017 6:58 am
by Paul
Big D wrote:14/2 plus ground, stranded
+1
Re: 110V AC
Posted: Tue Aug 01, 2017 10:55 pm
Thanks to all.
Re: 110V AC
Posted: Wed Aug 02, 2017 10:57 am
by WayWeGo
+1 on the stranded.
Our 1975 F36 has a lot of solid wire that looks to be original, so worth a check. I am slowly going through it and replacing with tinned marine stranded wire with crimp lugs. Check out
http://www.bestboatwire.com as a potential source of appropriate wire.
Re: 110V AC
Posted: Wed Aug 02, 2017 12:12 pm
by Paul
Paul wrote:Big D wrote:14/2 plus ground, stranded
+1
If you replace the wire from the inlet to the panel, be sure to use something a little heavier like a 12/2 stranded.
Re: 110V AC
Posted: Fri Aug 04, 2017 8:42 pm
by Big D
If the vessel's service is 30 amps (30 amp inlet/cord), it needs to be 10/2 plus ground from the inlet to the panel.
