LISTING TO STARBOARD
NOTHING ELSE MATTERS
Post by NOTHING ELSE MATTERS »
My 1983 9 meter international is listing to starboard. Any idea if this is normal ( i do not have a generator) ?
2024 Gold Support
2024 Gold Support
Re: LISTING TO STARBOARD
How much ? Normally boats will sit pretty level . But get loaded unevenly . Did have a genset that was removed ? was it off set ?
This boat never had a gen set. She leans about 3/4 of an inch or if I place 250 lbs weight at the port aft corner will correct it.
AlphaJustin
Post by AlphaJustin »
Mine starts to list to port when the water tank starts going down and black water starts filling and gets worse the more water that gets used. Probably not your issue but just thought I'd mention it.
Waste, water and fuel tanks are all in line in the center of the boat.
I asked before but i will ask again, is the 9 meter International cored with balsa wood below water line or hull sides?
No.
Landlocked
Post by Landlocked »
My 11 Meter Sedan also does this. I've always assumed it was because the lower helm station and 2 air conditioners are located on the starboard side of the boat without any significant offsetting weight on the port. Also, all the wiring and cabling going from the lower helm and the engine room to the upper one passes up inside the starboard wall.
Lake boaters skip the salt...
1985 11 Meter Sedan
1972 Newman Bassboat
1990 Cyclone Jetboat
Thank you for your responses. I still can't figure out what causing it.
