1975 Trojan F30 tween screw-slow leak into the boat. The leak is coming from where the exhaust pipe exits the boat and t
bemexem
Post by bemexem »
Hello All,
I have a slow leak into the boat. The leak is coming from where the exhaust pipe exits the boat and the pipe is capped on outside with an elbow that directs cooling water and fumes to the side of the boat (sorry don't know the proper term of the part). Anyway, it's secured to the stern with what appears like 4 bolts.
The question I have, would I need to take the boat out of the water in order to properly fox it?
Thank you
Trojan F30 tween screws
2024 Gold Support
2024 Gold Support
Re: 1975 Trojan F30 tween screw-slow leak into the boat. The leak is coming from where the exhaust pipe exits the boat a
It would be a good idea .
prowlersfish wrote:It would be a good idea .
+100
ken64k
Post by ken64k »
Yes, the boat needs to be out of the water for this repair. The exhaust tips should be removed, cleaned up and resealed with
3 M 4200 or similar sealant. Make sure the transom core is dry also.
Trojan F32 Flybridge 1975
Twin Ford 351s
Albany N.Y.
2024 Gold Support
2024 Gold Support
Transoms are not Cored on F boats I would us 5200 myself ( some hate it others love it )
prowlersfish wrote:Transoms are not Cored on F boats I would us 5200 myself ( some hate it others love it )
The devil's glue......
I use it on all my underwater fittings. Don't see the point of anything else where water can get into the boat.
2024 Gold Support
2024 Gold Support
Post by El L Sea »
The angel for the Devil.
2024 Gold Support
2024 Gold Support
The exhaust is right at the water line (mines Partly under ) Great stuff .
2024 Gold Support
2024 Gold Support
Where is it when you are on the boat? :P :P :wink:
