Railings!!
Hotchie
Railings!!
Post by Hotchie » Sun Apr 22, 2018 10:11 am
1987 trojan tri-cabin 36' screws on railing post pulled out any suggestions on repairs ?
2019 Gold Support
2019 Gold Support
Re: Railings!!
Post by prowlersfish » Sun Apr 22, 2018 10:24 am
The should be thru bolted . The right way to repair it is to replace the screws and the nuts and washers on the back side . Make sure you use a sealant like 3m 4000
TROJAN F36 Conv.
2009 TROJAN RENDEZVOUS
2019 Forum Supporter
Location: Near Baltimorgue, where Maryland proves to the nation every day that gun control doesn't work.
Re: Railings!!
Post by P-Dogg » Sun Apr 22, 2018 5:46 pm
Prowlersfish was in a hurry and forgot to add the part about, for each of the three stanchion bolts, drilling the largest hole that is still shadowed by the stanchion footing, filling it with epoxy, then drilling new 1/4+ " holes into the epoxy, thus shielding the core from water ingress. Be sure to chamfer the 1/4+" hole in the epoxy generously, thus making a void guranteed to allow complete sealing of the thru bolt with sealant.
I like six 10, or the Jamestown distributors cheaper alternative for filling holes. All of my weatherdeck hardware is so treated. Next owner: you are welcome.
If it's the one over the bathtub, lemme know and I'll share how to reach that when I'm typing on a computer.
Hotchie
Re: Railings!!
Post by Hotchie » Sun Apr 22, 2018 7:34 pm
Sorry for the double post guys didnt see first post thanks for the info!!!
