Trim tabs
Posted: Thu May 10, 2018 2:25 pm
by Hotchie
Looking to replace hydraulic hose on trim tabs looking for any advice! Like how does the hose go through the transom? if it’s just standard hydraulic hose that you buy or where can I buy hose for trim tabs?
Re: Trim tabs
Posted: Thu May 10, 2018 5:44 pm
Just goes thru a hole in the transom The hole is coverd with a "clam shell . You can use Hydraulic hose . I have use Automotive Trans cooler line .
Per Instatrim
"Hydraulic Hose: Hose has 1/4 inch inside diameter 1/2 inch outside diameter 400lb.s working pressure and 1,600 burst pressure."
Re: Trim tabs
Posted: Fri May 11, 2018 5:55 am
by Hotchie
That’s awesome thank you so much for that information my friend! Very much appreciated
