Few questions. Setting carbs / New windows
2019 Gold Support
2019 Gold Support
Re: Few questions. Setting carbs / New windows
Post by WayWeGo » Thu May 24, 2018 9:32 am
A wise mechanic told me: "If you think you have a carburetor problem, check the ignition system. Once you have completely checked the ignition and are sure it is the carburetor, check the ignition again."
That said, it is good that you found the air screw turned all the way in. No way that could help the situation.
marklo154
Post by marklo154 » Tue May 29, 2018 8:56 pm
The ignition system seems to have become a popular issue with a few people trying to help me trouble shoot this issue. I have old distributors and a few have suggested I get complete new electronic system with new distributors. I have looked online but not sure which one I would need ? It looks a bit pricey but I would like to use my boat.
1978 Trojan F36 Tri Cabin
Reel Easy
Post by Reel Easy » Mon Jul 09, 2018 7:20 pm
Any progress on this? I am having a similar problem.
Dustin
1999 360 Express twin 7.4
Catawba Island, Ohio
Boppy
Post by Boppy » Tue Jul 17, 2018 2:24 pm
Just a thought about your gas tanks. Are they original galvanized metal or have they been updated to plastic, FG or aluminum. My 77 F26 had fuel issues that sound a lot like yours, but I'm only running one engine, the Chrysler 318 with Rochester 4bbl carb. Turns out the original galvanized tank (70 gal) was rusting on the inside and that was causing fuel blockage. Replaced with 50 gal plastic tank in 2001 and have not had issues since. I also use non-ethanol gas available at nearby Marina. Just don't trust E-10 to be lying around in my tank during winter storage here in upstate NY. Hope you get this figured out.
Reel Easy
Post by Reel Easy » Thu Aug 02, 2018 8:55 pm
Try changing out the distributor to Pertronix. Mine was Chrysler electronic. It would run great leaving the dock and at high RPMs anything above 900 RPM. Coming back to port it would stall in the middle of a busy channel. The problem was the distributor its self. I had changed out everything else. Fixed.
Dustin
2019 Gold Support
2019 Gold Support
Post by WayWeGo » Fri Aug 03, 2018 12:05 am
Reel Easy, it is good to hear you got it fixed!
marklo154
Post by marklo154 » Sun Aug 05, 2018 4:58 pm
Update.
Still battling this issue. I have eliminated fuel as he issue. I ran the boat of some brand new outboard tanks with fresh gas and got the same result. ( getting pretty good docking this thing on one engine )
I have had 2 different mechanic come out, one says its the carbs, the other says its the distributors. Both of which are what 30 plus years old. I am almost considering purchasing 2 brand new carbs and to electronic ignition kits with the new distributors. i mean what else could it be.
Reel Easy
Post by Reel Easy » Sun Aug 19, 2018 8:56 pm
Try switching parts from port to starboard.
Dustin
Reel Easy
Post by Reel Easy » Sun Aug 19, 2018 9:01 pm
Also do a voltage drop down test. Do it cold then when its warmed up, both engines and record your data
Dustin
