1973 ft trojan sport fish how fast and other info please
scubajohn
Post by scubajohn »
hi i am new here i am getting a 30 ft sport fish 1973 with twin chevy 305s
the prieviose owener says it will go 34 mph or 30 knots if lightly loaded
what do you all think?
also can i cut a transom door in i can do the glass work but will i ruin the hull? i want to go diving and fishing and would like the door
thanks john
2024 Gold Support
2024 Gold Support
My f30 (1977 clean machine ) with 351 fords never saw 30 knots . with a very clean bottm I could cruse at 21 knots . Top speed maybe 26 knots or so . boat was very sesative to growth on shafts and rudders and of course props. did you sea trail the boat ?
As far as the door yes it can be done if you know what your doing . a frend is doing his F36 . But that some thing I would never try myself
crazyhorse
That would be blinding fast
Post by crazyhorse »
I have a 73 32' sportfish and it doesn't do much better than 15-20 depending
1973 Trojan Sportfish owner "CrazyHorse"
jddens
Post by jddens »
My F30 with fuel injected 330hp 350's will hit 30 flat out lightly loaded and trimed (only did that 1 time)......I max cruise at 18-20 at 3100, again, lightly loaded...........this year with fuel costs what they are, I will be crusing much slower, more like 8 knots at hull speed.............John
1998 Kawasaki ZXi 1100
jddens
Post by jddens »
scubajohn
Post by scubajohn »
hi and thanks for the replys i have not bought the boat i saw it from the outside and talked to the owner he claimed 34 mph this seamed high
then i went to look at the boat the inside is gone there is no deck left even the bulkhead/back wall with the door is gone i would say every piece of ply wood in the boat is gone or rotten i dont think it would be worth the effort or money what would it be worth fixed up
thanks
John
LandVF36
Post by LandVF36 »
I have a 1978 Trojan performance spec sheet. It shows the following
F-30 w 305s, at 4000 RPM it says you'll do 28.7 MPH. At that point they will be drinking 25.5 GPH of fuel.
At 3000 RPM, it says 13.9 MPH and 13.8 GPH in Fuel
At 2500 RPM, 9.2 MPH and 9.7 GPH of fuel.
It does not list what wheels, tranny ratios or anything else.
Hope that helps.
Mitch
Current Fleet:
2000 Carver 450 Voyager
1994 Scout 15'
2005 Caribe LCX9 dingy
1981 16' Hobicat
mr elevman
Post by mr elevman »
wheels on my 1972 30' express are 14" 11p and bolth are stamped 10/71 so i guess thair orig
BMac
1972 Sea Raider
Post by BMac »
I have 318's in my 30 foot Sea Raider, top speed I have managed to get is 33.5 mph (on GPS). Perfect conditions no wind, flat lake but fully loaded, gas tanks full and while on a two week vacation so the boat was loaded with weight.
Bill
etpence
Post by etpence »
hello all
I have a 30' 1974 sea raider that I repowered with 5.7mpi's 330hp w/hurth trans.
with 3 persons and full fuel 160gal I have at WOT 5000rpm
hit 41kts on calm sea trimmed out (GPS reading)
I fish offshore gulf of mexico and cruze at 26kts at 3600rpm
I replaced all tankage with alum. tanks and replaced the intire deck with lighter but stronger composit stringers which reduced my gross weight by about 1500lbs
Regards todd
30'trojan sea raider
Mio MIo 8)
