318 F-25 won't run
AlphaJustin
318 F-25 won't run
Post by AlphaJustin »
Changing the bendix drive on the starter as recommended by Facebook will check back if I have further questions. (It wouldn't let me entirely delete this post sorry.)
AlphaJustin
Re: 318 F-25 won't run
oldboat1
Post by oldboat1 »
Just FYI. It could be a flywheel issue (missing gears), or starter placement -- could require shimming the Bendix gear in toward flywheel. I went through this with a 305 in a Chris Craft. (Although not quite the same -- gear would periodically spin on mine without engaging the flywheel.)
1980 F26, Mercruiser 305
