removing screens 73 trojan tri cabin
Bruce
Post by Bruce » Sat Oct 15, 2005 6:05 pm
I have a 73 trojan. The screens are a little tired and need to be repaired. I can't seem to get them out the way the windows are designed. Any suggestions would be appreciated.
b_critical
Post by b_critical » Tue Oct 25, 2005 2:09 pm
Good question any responses? :?:
banks
Post by banks » Mon Nov 28, 2005 12:26 am
Short of disassembling the trim around the frames inside, you will not be able to. If you do go thru this, you will see a small piece of al chanel at the top of the frame, inside, which has to be removed. Be careful , the screws are difficult to remove and can be damaged, especiallly in the 36 ricabin aft windows. I found that drilling the head of the screw off and then removing the screw was the most efficient. Be carefl not to drill the chanel. It is much softer than the screw. Good luck
Jim Banks
North Carolina
dmatz
Post by dmatz » Sat Apr 08, 2006 1:31 pm
I replaced the screens on my 72 Tri Cabin. It had screws in the bottom L shaped channel of the window frame. They were tough to get out due to corrosion. The screws are threaded into the window frame. Once they are removed you can remove the L shaped channel and tip the bottom out and slide them out of the top channel. I suggest after you get them out retapping the holes and replace with stainless screws. You may need to remove any wood molding if possible to get access to the screws. Look in the lower channel and see if you can see the screws first. Hope this helps.
Dave Matz
