BACKFIRE AT WOT STARBOARD ENGINE
PLAYMATE
Post by PLAYMATE »
IT SEEMS I MAY HAVE A CARB PROBLEM. WHEN I START UP RUNS GREAT FROM 750 - 3000 RPM RUNS FINE, WHEN I OPEN UP TO 3200 RPM THE 4 BARREL KICKS IN AND I GET A CONSTANT LITTLE BACKFIRE , SOUNDS LIKE A MACHINE GUN. POP,POP,POP,POP,POP. WILL NOT GO OVER 3200. I WAS RUNNING 34-3600. NOT SURE WHAT IT COULD BE?
ITS A CARTER AFB, STANDARD ISSUE.
csgt428
Re: BACKFIRE AT WOT STARBOARD ENGINE
Post by csgt428 »
Sounds like a lean condition. If you had access to a known good carb and swapped it out temporarily you could isolate the problem to the carb if it runs OK afterwards. Could be any number of problems though.
1963 36' Sea Voayager
Steady pop ? Could be a worn exhaust cam lobe a weak intake spring .
