Ford 351 w / merc 233
Captrichc
2019 Gold Support
2019 Gold Support
Post by Captrichc » Sat Dec 15, 2018 6:58 pm
does anyone else have these engines? If so do you have a 2BBL or 4 BBL carb and intake? did that engine come with a 2BBL option from Trojan? trying to get to the botton of this.
1974 f32 Sedan
Twin 233 Mercruisers
2019 Gold Support
2019 Gold Support
Re: Ford 351 w / merc 233
Post by prowlersfish » Sun Dec 16, 2018 5:24 pm
The 233 hp Merc was offered by Trojan It was a 351W Ford based engine . It came with a 2 barrel carburetor only . The also offerd a 255hp that was a 4 barrel . I have owned both
What questions or issues do you have ?
TROJAN F36 Conv.
2009 TROJAN RENDEZVOUS
Captrichc
2019 Gold Support
2019 Gold Support
Post by Captrichc » Tue Dec 18, 2018 5:53 am
you just answered them. sending the carbs out to be rebuilt.
1974 f32 Sedan
ken64k
Post by ken64k » Tue Dec 18, 2018 6:56 pm
I have the ford 351 in my 1975 F32 with the 2 bbl carburetors. The motors run fine. The only issue I have is I had to put manual chokes on them. Both motors want to be fully choked on the first start, as soon as the motors start I can fully open the chokes and they run just fine.
Trojan F32 Flybridge 1975
Twin Ford 351s
Albany N.Y.
Captrichc
2019 Gold Support
2019 Gold Support
Post by Captrichc » Sun Dec 23, 2018 12:42 am
What kind of RPMs and WOT speeds are you getting?
1974 f32 Sedan
ken64k
Post by ken64k » Sun Dec 23, 2018 8:22 am
To tell you the truth I never ran it at WOT so I can not give you those numbers. Most of the time I run between 3000 and 3200. AT 3k I running around 16 MPH.
I like to keep the speed down so I can see my surroundings.
Twin Ford 351s
Albany N.Y.
Captrichc
2019 Gold Support
2019 Gold Support
Post by Captrichc » Thu Dec 27, 2018 5:54 am
Im getting 3200 at WOT 16 mph. I should be getting 3600 easy.
1974 f32 Sedan
2019 Gold Support
2019 Gold Support
Post by prowlersfish » Thu Dec 27, 2018 6:44 am
WOT specs are 3800-4200 rpm
TROJAN F36 Conv.
Captrichc
2019 Gold Support
2019 Gold Support
Post by Captrichc » Thu Dec 27, 2018 8:08 am
..... im trying to work from the engine back. Carbs are being rebuilt now. Would timing also lower RPMs at WOT?
1974 f32 Sedan
2019 Gold Support
2019 Gold Support
Post by prowlersfish » Thu Dec 27, 2018 12:10 pm
Yes timing sure could
TROJAN F36 Conv.
Captrichc
2019 Gold Support
2019 Gold Support
Post by Captrichc » Thu Dec 27, 2018 1:11 pm
Ok. New plan. Carbs being rebuilt. Changing the points to electric ignition. Will reset timing. Changing the plugs amd wires.
Wil check to make sure that the carberators are opening up all the way and that the cable doesnt need to be adjusted.
Replacing the fuel filters to make sure there is no restrictions there.
Checking with a tachometer gun to make sure the tachometers are reading correctly.
1974 f32 Sedan
2019 Gold Support
2019 Gold Support
Post by prowlersfish » Thu Dec 27, 2018 6:20 pm
Good plan
TROJAN F36 Conv.
willietrojan
Post by willietrojan » Thu Dec 27, 2018 7:08 pm
My F32 had 233hp Merc's and they were very good engines. As to the RPM question, I would hit about 4200 - 4400
depending on load, Gas, etc.
Spanish Fort, Al
Looking for 33 International
Captrichc
2019 Gold Support
2019 Gold Support
Post by Captrichc » Thu Dec 27, 2018 9:56 pm
Thanks Willie. At least i know what i am striving for.
1974 f32 Sedan
