How do those hook up?
Cappy's f32 rehab
Re: Cappy's f32 rehab
Directly to the NMEA backbone, that's why I like them. This is my engine room temp sensor.
Simrad system will be delivered today. Cant wait to set it up. I want to redo the witing b4 i seal the deck again for easy access.
Also i designed my new hatch. I will post pics later tonight
1974 f32 Sedan
Twin 233 Mercruisers
Here are some pics of the new system.!!!!
- 20190225_174941.jpg (56.01 KiB) Viewed 7835 times
- 20190225_174947.jpg (20.66 KiB) Viewed 7835 times
- 20190225_175036.jpg (69.84 KiB) Viewed 7835 times
- 20190225_175057.jpg (64.11 KiB) Viewed 7835 times
- 20190225_175221.jpg (54.52 KiB) Viewed 7835 times
- 20190225_175441.jpg (61.64 KiB) Viewed 7835 times
- 20190225_174657.jpg (50.77 KiB) Viewed 7835 times
1974 f32 Sedan
Now i need to figure out where to mount the total scan transducer.
1974 f32 Sedan
Very nice
- WayWeGo
I have the same radar and like it a lot. If only I knew how to take advantage of all its features. Then again, I really enjoy learning how to use it!
Ordered my nmea 2000 network today, along with the Nolan rs11, 2 lowrance fuel flow sensors. My birthday came a few days early
1974 f32 Sedan
Both new tanks are installed and all hoses ran. Reimstalled pressure pump for fresh water and installed the saltwater wash down pump. Tomorrow ill take up the electric for everything and stsrt the template for the floor.
1974 f32 Sedan
- WayWeGo
You're on a roll! Keep up the good work and thanks for keeping us in the loop!
Just picked up my props they look almost brand new.
- 20190308_100927.jpg (64.8 KiB) Viewed 7702 times
1974 f32 Sedan
Cleaned up the wiring today. Ill take some pics once i have everything mounted where it needs to be b4 i make the template for the floor itself.
1974 f32 Sedan
Template made for the floor. Cut the wood and i am going to be installing the deck today.
1974 f32 Sedan
Some new pictures.
- 20190312_104435.jpg (98.6 KiB) Viewed 7563 times
- 20190312_104449.jpg (90.93 KiB) Viewed 7563 times
- 20190312_104915.jpg (67.63 KiB) Viewed 7563 times
- 20190312_104926.jpg (82.5 KiB) Viewed 7563 times
- 20190312_104928.jpg (82.41 KiB) Viewed 7563 times
1974 f32 Sedan
