Hello,
I have a F36 with four gas tanks. Does anyone have photos, or can they describe where to cut panels to access the senders? I think I've got the rear tanks figured out, certainly not the forward tanks... Thanks, Jim.
F36 Fuel Sender Access Panels
- JimmyDutch
1985 Trojan F36 Convertible 460
Twin 350 Crusaders
Twin 350 Crusaders
Re: F36 Fuel Sender Access Panels
I cut a hole to get mine out ( covered it later ) Per some posts you maybe able to remove a panel . Anyway below is what I did with photos . and I still recommend wema senders .
viewtopic.php?f=1&t=8284&hilit=wema
viewtopic.php?f=1&t=8284&hilit=wema&start=15
- JimmyDutch
Once again, thank you Prowlersfish!
Twin 350 Crusaders
Twin 350 Crusaders
- JimmyDutch
Hey Prowlersfish, The circular hole you made appears to be on the port side, do you think if I made a hole on the starboard side, inside the cabinet in the same spot you did on the port side, I would find the sender? Did they appear to mirror each other? Thanks, Jim.
Twin 350 Crusaders
Twin 350 Crusaders
I did both sides But I found the senders before cutting a hole you should be able to find the area with the floor panel between engine hatch and cabinet removed . My tanks are not oem so location may been off some
- JimmyDutch
Thanks Prowlersfish,
I also read the rest of the original thread that your pictures were in and it makes a lot of sense to me now. Thanks for taking the time, Jim.
Twin 350 Crusaders
Twin 350 Crusaders
Don't want to hijack in any way... but need to do a +100 on WEMA!
Short story (hopefully), and Moderator can move it to a new thread or leave it here as he desires based on whether on or off topic..
Years ago (close to 20) just after I bought my F32, I needed to replace level sender for the fresh water tank. Determined that a WEMA sender would be compatible with my existing gauge, so ordered it through a somewhat local dealer. Waited weeks. Waited months. After about 6 months got fed up. Dealer kept saying delay was Distributor's fault, Distributor kept saying it was WEMA's fault.
Got PO'd enough to call WEMA directly, explained my problem to receptionist (ordered your product months ago and can't get it, but don't know who is lying to me about why), and asked to talk to someone who could help fix the problem. She transferred me to someone.
Turns out he was owner of the company. Took the call from his cell on a golf course. Asked what it was I was trying to order, my name / address / contact info, and said he would look into it when he got back to the office. 2-3 days later a courier dropped a package off at my door -- containing the sender I had been waiting for, for months. To be honest, can't remember if I even paid for it or if it was just sent free of charge!!!
WEMA rocks.
This winter I changed the head on the boat from original recirculating model to a new macerating unit. Decided I needed a tank level sensor to know when near full and time for pumpout (previously I could keep track of how full the tank was based on how many times I had transferred contents of the recirculating head to the holding tank). Ordered in a WEMA sensor / gauge for 'my guy' to install with the head.
Again, WEMA rocks!
WEMA rocks.
Again, WEMA rocks!
- JimmyDutch
Wow! Good to hear. Thanks.
Twin 350 Crusaders
Twin 350 Crusaders
