Re: Fresh water tank on a 89 10 meter mid-cabin
Posted: Thu May 07, 2020 3:56 pm
Hey! Did you ever find the other end of that water hose?
I have a 1986 Trojan 10 Meter Express, Mid Cabin. I checked my forward bildge to find 2 inches of water. I drained it well and started drying it up when I saw a drip coming from my hose that is connected to the screen/filter that connects to the water pump. So we tightened the clamp up some. That did the trick as far as the drip goes. But as I sop up that water, more slowly appears from beneath the fiberglass bridge that the bildge pump sits on. It's like a plate that it sits on. The water slowly appears from there.
I believe that it may be dripping from the other end of this hose I just tightened up. And would LOVE to know how to access it without drilling holes. Not confident in doing so.
As I have read this entire thread I am wondering, could the hose run under the stairs? For example, if I were able to remove the top of the first step, would I be able to see the water tank and possibly the hose attaching to it? Or does it connect lower, beneath the tank?
I am so close to resolving this. I can feel it!
