Page 2 of 2
Re: What’s wrong with this picture?
Posted: Sun Jan 05, 2020 2:48 pm
by WayWeGo
Here are photos of our trim tabs on a '75 F-36. As I recall, our boat is about the same year as Oil and Water's was.
And if you zoom in, you will be able to see that the prop nuts are backwards. That is the way we got the boat and I have not had a reason to take them off, but when I do, they will be installed correctly.
- 20160601_183444.jpg (120.13 KiB) Viewed 6272 times
- 20160620_172154.jpg (64.79 KiB) Viewed 6272 times
Posted: Sun Jan 05, 2020 6:35 pm
by Briank117
WayWeGo,
Are your swim platform brace arms just regular bolted stainless tubing? Or welded?
Posted: Mon Jan 06, 2020 10:19 am
by WayWeGo
Its all regular stainless tubing. I suspect it did not come from the factory, but not sure.
Posted: Mon Jan 06, 2020 1:11 pm
WayWeGo wrote: ↑Sun Jan 05, 2020 2:48 pm
I am going to recheck with Bob and John on the tabs
Posted: Mon Jan 06, 2020 4:18 pm
by mikeandanne
Briank117 wrote: ↑Thu Jan 02, 2020 3:48 pm
Anything look off here?
Maybe the pic angle, but to me the rudders seem much larger than what we had on our 78 F32, which is a good thing , and our tabs were mounted on the transom like instatrim directions.
Posted: Mon Jan 06, 2020 6:18 pm
UPDATE
The recessed trim tabs on WAYWEGO's boat and The F36 photo I posted were indeed Trojan factory . The early ones were billed as a "SportFish" . You will notice beside the cylinder the tabs a recessed in the bottom also . I wish mine were like that .
Posted: Sat Jan 11, 2020 9:38 am
by Big D
prowlersfish wrote: ↑Fri Jan 03, 2020 6:45 am .....Prop nuts by the book thin nut first then the thick nut .....
No ya did it, you went and opened up a can of worms again
Some will argue, but yes, thin (jam) nut against the prop, then the thick nut last. The proper way to install a prop is to slide the prop on, use the thick nut first and tighten it to set the prop in place as you should not use the jam (thin) nut to tighten the prop, then remove the thick nut and install the jam nut, tighten, then finish by tightening the thick nut onto the jam nut. In the end, you're left with the thin jam nut "jammed" against the hardware by the thick nut, that's how a jam nut is designed to work. Often when props loosen off, it's likely due to an impact, vibration, or the nuts aren't installed properly. And yes, if you look at all the boats in a marina, it's common to see 98% of them with the thick nut against the prop.
Usually when a hull is designed to accommodate mounting trim tabs on the bottom of the hull, the mold incorporates an indent for the tab hinge to be mounted in as seen in the above photo.
Posted: Sat Jan 11, 2020 10:27 am
Big D wrote: ↑Sat Jan 11, 2020 9:38 am
Agreed great info as always . I will add make sure the key is not to far up the shaft . Good idea to fit the prop with out the key to see how far up the shaft it goes ,mark it. then make sure it goes on the same with the key . Then install as Big D said .
Can of worms ? Its what I do
Posted: Mon Feb 03, 2020 8:45 pm
by Diverted Income
Interesting. The tabs on my F-32 are mounted on the bottom. Original as far as I know. Boat Leveler '82 Hmmm..
Posted: Thu Feb 06, 2020 11:58 pm
by P-Dogg
I'll take "The way the US navy does it" for $1000 Alex.
https://fas.org/man/dod-101/sys/ship/nstm/ch075.pdf
See page 75-96 or so....
Posted: Fri Feb 07, 2020 5:48 pm
by Big D
That’s a great resource and a perfect explanation of why you are supposed to end up with the small jam nut first followed by the larger main nut.
