Back light for guages
HiredKiller
Post by HiredKiller »
I recently purchased a 1986 Trojan 11 Meter and am in the process of learning systems. Do the back lights for the gauges come on with the Nav lights switch?
2020 Gold Support
2020 Gold Support
Re: Back light for guages
I don't believe so , but I don't own a 11 meter so I am not a 100% sure . Do you have a owners manual ?
TROJAN F36 Conv.
2009 TROJAN RENDEZVOUS
fourreins
Post by fourreins »
My 10.8 meter has a switch for the panel lights
fourreins wrote:
Mon May 18, 2020 10:18 pm
Same here on my 1983 10 Meter
separate switch
has a resistor in the dash to dim the instrument lights
Twin Yanmar 315 Turbodiesels
2020 Gold Support
2020 Gold Support
Post by El L Sea »
My '88 12 meter has a separate switch.
I am actually in the process of converting them all to LED, and adding a dimmer switch.
HiredKiller
Nothing seems to come on when I turn on the panel lights switch. There doesn't seem to be a Fuse/ Switch for panel lights at the main panel? I could not find any information on this in my owners manual.
2020 Gold Support
2020 Gold Support
Post by El L Sea »
HiredKiller wrote:
Tue May 19, 2020 10:10 am
My big problem was grounding issues, as the "backplane" of the gauge cluster acts and the ground for all the lights. The PO had done a bunch of weird stuff, so it was easier to kind of start from scratch with the original wiring diagram from Beacon.
