Anyone put wood paneling on their ceilings
I had an idea of putting thin wood 4x8 sheets of cherry paneling up ? Would it stay if I use adhesive.im not sure of the thickness of the wood that up there now and don't want to go thru to the outside.will it sag in the middle
- IMG_20200606_170025112_HDR.jpg (129.75 KiB) Viewed 5655 times
Re: 1972 Trojan newbie on kitchen upgrade
House Boat ?
Yes it's a 34 foot house boat
Re: Anyone put wood paneling on their ceilings
I have not seen that done ever
I don't know why it won't. I have this ugly cover on it now that looks like car head liner in it now which is rip in places and under neath is plywood varnished. Put still plywood
I said I have not seen it done not that you could not . If it was mine I would replace the head liner . But its yours so you can do it your way or anyway you please . You have to look at and like what you see , not me ( not a fan of paneling )
I used 1/8 Luan plywood on the ceiling of my F26. Painted white and used 1 1/2 battens on the seams. If you have a solid ceiling to attach it to contact cement might work well.
I had to repair a previous owner repair and used white oak sheets that I coated with epoxy on the back before installing. Then stained and varnished to match the other wood.
- A3586A2E-EF6F-47E0-93D7-D205D21A3E1C.jpeg (101.43 KiB) Viewed 5130 times
- CE756184-40F3-44D3-B3D3-1BD210DF1CE3.jpeg (196.01 KiB) Viewed 5130 times
- 832A8972-31B5-4876-BA90-EFFA24BAF20D.jpeg (154.22 KiB) Viewed 5130 times
I have not, but I plan too. Mine has wood slats that I plan to screw and glue to.
