Fresh Water Pump
Posted: Fri Sep 10, 2021 5:28 pm
by jfgkahaluu@gmail.com
My Fresh Water pump stopped working, swapped it out and nothing. No power coming to the pump, is there a fuse somewhere? Just a toggle switch on the panel. 1989 10.8 international.
Re: Fresh Water Pump
Posted: Wed Sep 22, 2021 11:25 am
by mrrudely
I understand toggles on electrical panel are actually breakers.
Do they go bad?
Posted: Wed Sep 22, 2021 12:19 pm
by BobCT
Correct, they are Airpax breakers. I assume it's not tripped? I would remove the panel and supply 12v at the switch wires and see what happens. Then you can rule in/out the breaker switch. Yes, I haven't had any go bad myself but some people have.
Posted: Mon Oct 11, 2021 6:28 pm
by oldboat1
On-demand pump when the switch is on. Water tank filled?
My F-26 uses pull-switches mounted on the lav bulkhead (one for the shower pump and one for water supply.) They are prone to corrosion and need periodic cleaning.
