Air Conditioning
Air Conditioning
I have a 1985, 10 meter international. It has the aqua temp air front and salon. I recently had the salon unit recharged but couldn’t get complete access to the front birth. I removed the vent cover but am unable to gat the full patriot off. It will not go past the wood border on the small table space. Do I have to remove the metal strip to get at the wood screws to remove the border. Seems like a lot of work,and there must be an easier way to recharge the front unit
Thanks for the info
Re: Air Conditioning
Odd that both units are low. What refrigerant are you using? Any photos of the area? I am not sure what you mean by patriot? I can do some research or You can call Bob at Beacon. But Need to know what boat you have. You said you have a 10 meter but they made 6 different 10 meters and they are all different. Express, mid-cabin(that some owners think is an express) Aft-express. Sedan, Aft cabin sedan and one with open lower helm.
Tks for the reply. I have the 10 meter international, fly bridge. Meant partition in outline, had another problem with the salon air and needed it repaired. As a result had to recharge and wanted the birth unit looked at as well. A picture may be appropriate.
Thanks for the info
On the 12m sedan access is through a panel in the back of the starboard locker. Picture is of the space during the replacement of ours (picture is turned on it's side for some reason):
Re: Air Conditio
- B847AE03-EFC2-4CAC-9251-1D6909CFF397.jpeg (123.62 KiB) Viewed 2911 times
Thanks for the info
