Does anyone have any tips for removing the Crusader 350 engine impellers?
Winterizing an F32
Winterizing an F32
Geri
Trojan F32
Robesonia PA
Summers on the upper bay in MD
Trojan F32
Robesonia PA
I don't have experience with crusader, but on my Chrysler 318 - removing the impeller with the pump mounted on the motor, in the boat, is a hopeless proposition. I removed the raw water pump from the engine. Only then can I open the housing to remove the impeller. This is the first season that I pulled the pump with the engine in the boat. (This is only my second season with this boat. It was easly last year, because I had pulled the engine from the boat to rebuild it.) After seeing what a chore removing the pump was with the engine in the boat, I'm wondering how many people pull the impeller every season? I hope its not too difficult to re-mount the pump with the engine in the boat. I think it will be a tough squeeze, but not impossible.
Good Luck
Chuck
Good Luck
Chuck
formerly
Lots A Luck
Trojan F-26 Express
Narragansett Bay, RI
Lots A Luck
Trojan F-26 Express
