Sliding glass door
rolytrojan
Sliding glass door
Post by rolytrojan » Sun Sep 21, 2008 9:23 pm
I need help on replacing the wheels on the sliding glass door on a 12 meter. It has been on my long list to do. It is getting very difficult for the kids to slide the door.
Any tips in replacing the wheels would be helpful. Also, any idea in where I can buy the replacement wheels.
Thanks for your help,
Roly
1985 11 Meter International Convertible
6-71TA
wowzer52
Post by wowzer52 » Sun Sep 21, 2008 11:29 pm
hmmm.... I need to do the same on my F-32. I'll be watching too for advise.
1975 F-32 "SIMPLY BLESSED"
trepka2001
Post by trepka2001 » Mon Sep 22, 2008 10:03 pm
me too!!
Safari
Post by Safari » Mon Sep 22, 2008 10:59 pm
On my f36, in order to replace the rollers, remove the bottom track screws, Then, pull the bottom track and the door (at the bottom) out a little bit. The door is captive on the bottom track. It is helpful to have another person with this - Pull the bottom out, then down a little to allow the door to drop out of the top track, then set the door down. Pull the bottom track off and the wheels will be exposed. Be prepared to deal with stripped screws holding the rollers in; if you replace the rollers without repairing stripped screws, the door may continue to rub (don't ask me how I know this).
Location: Colonial Beach, VA- The Play Ground on The Potomac
Post by Stripermann2 » Tue Sep 23, 2008 10:15 am
As to the original question on your 12 meter, I have no idea but as Safari posts, it's a piece of cake on the F series, just as he described.
Check with John at Marine Tech, I bought my last set of roller wheels from him a couple of years ago. 717-684-4145
Good Luck.
tgcasey
Post by tgcasey » Tue Sep 23, 2008 11:14 am
I have the same boat and replaced the rollers and it is pretty straight forward to do. Remove the screws that hold the door in place and simply unscrew the rollers.
Tom
rolytrojan
Post by rolytrojan » Wed Sep 24, 2008 9:05 pm
Stripermann....
Thank you. I will call john tomorrow to find out if he has the wheels in stock.
Has any 11 0r 12 meter owners change the wheels on the sliding door???
Thanks,
Roly
6-71TA
tgcasey
Post by tgcasey » Thu Sep 25, 2008 7:38 am
I have a 12M convertible and I changed the rollers on mine...
rolytrojan
Post by rolytrojan » Thu Sep 25, 2008 9:22 pm
tscasey,
Any advice in changing the rollers.
Thanks,
Roly
6-71TA
tgcasey
Post by tgcasey » Fri Sep 26, 2008 8:12 am
It is actually very straight forward to change...
Once you get the door out, lay the door on its side and slide the bottom track off. There are two rollers per end and if I recall correctly one is a ball bearing roller and the other is plastic. The ball bearing roller comes off with a 7/16 and the plastic one is on with a regular screw. Once you have the new rollers on slide the bottom track on and put the door back in place and secure the bottom track and your done
I did mine by myself but it would be easier with two people
Good luck
Tom
jenny5555
Re: Sliding glass door
Post by jenny5555 » Tue Aug 06, 2019 3:45 pm
I would just replace the door. I noticed that once i replaced the wheel it didn't last very long. I got my new door from home windows dallas, but i'm not sure they do boats.
tcollins2
2019 Gold Support
2019 Gold Support
Post by tcollins2 » Wed Aug 07, 2019 8:48 am
Following this, any pictures? Part numbers? Kids and wife would like the rollers changed on my 12M Express too.
2019 Gold Support
2019 Gold Support
Post by prowlersfish » Wed Aug 07, 2019 12:10 pm
Its a 11 year old thread , But Beacon marine should have what you need
TROJAN F36 Conv.
2009 TROJAN RENDEZVOUS
tcollins2
2019 Gold Support
2019 Gold Support
Post by tcollins2 » Wed Aug 07, 2019 1:53 pm
LOL, I didn't see that.
