I have 8v71 dds, and they need to be rebuilt. Is there a trick to getting the pan off in order to change my pistons and sleves in the block. Removing the block is almost impossible. Can I just jack up the engine and trany?
Looking for some magic
Robert
Rebuild in the boat 8v71 DD
how much room do I need?
how much room will i need to get the pan out, and can I not pull the crankshaft from below If I need to ?
I don't know how much you'll have to lift but I would expect 12-16" and of course very well supported with a secondary safety support (awful lot of iron in detroits).
You will have to remove the tranny to get to the rear main seal anyway and it will make access easier so I'd just do it straight away.
I've never done one but I've hear that if the crank needs to be removed, the block really should come out. I would imagine it's doable in the boat but getting the crank back in from the bottom without nicking anything doesn't sound fun.
