Oil pressure Crusader 454's
I have a 1985 10 Meter International with Crusader 454's. Can anyone tell me what the acceptable range of oil pressure at different operating conditions is?
- Stripermann2
- ready123
As gauges are not that accurate the key thing is to have pressure.
So the real thing you should look for is the needle level at initial start idle and then as engine warms up, what is it while running at say cruise.
The fact that it shows pressure change from stopped to run and some change cold to hot is more important than any single number it might register in my opinion.
- alexander38
Use the GM rule Paul gave out if you don't have a base line. Why do you ask ? Has yours changed ?
