Hi everyone. Could someone please tell me where the valve is that selects between dockside water and fresh water holding tank water on a 1981 F-36?
Thanks,
Larry
Fresh water selector valve location
I don't think there is a valve. Perhaps an F-36 owner can confirm. Every system that I've seen simply works off dockside when you attatch the hose (power down water pump). When you disconnect from dockside, power up the pump and draw from the tank. Most dockside water fittings have a built-in check valve to prevent water exiting when you turn on your pump. The pumps have check valves so that your tank doesn't fill up while connected to dockside water supply.
unless he or another owner made some modification. the original is the same as a rv water connection with the check valve, if you have to replace for any reason go to a rv parts place.
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
always be sure to turn dockside water off when you leave the boat for any period of time
TIKI III
1985 F32
270 Crusaders
Wet and happy
1985 F32
270 Crusaders
Wet and happy
