Looking at purchasing a 78 306 Express w/ Chrysler 318's.
Vibration from engines is in my opinion excessive. MY opinion.
What is a major cause of this.. what do i need to look for?
Thanks in advance
Express 306 Vibration at 2000 rpm and above
hard to tell
Hard to tell - I'd leave that to your Surveyor..
Well...... I did make him aware of my concern
I did. I mentioned that. He said inline's vibrate like that. I am used to inboard / out boards and outboards and had a V drive Carver.. but none of them vibrated like this sucker. Is this normal? Is there an increased amount of vibration with inline's that I should not worry about? Props looked good during the haul out.
>He said inline's vibrate like that. Who is he? The previous owner? The surveyor? Vibrations can come from bent shafts, props, engine mounts loose or out of alignment or a worn out cutlass bearing. From the engine itself, misfire is a possibility. Does it vibrate only in gear or also in neutral? You could try to find a similar boat to compare vibration. Caution is the best policy if something doesn't seem right it probably isn't.
Good Luck
Chuck
Good Luck
Chuck
formerly
Lots A Luck
Trojan F-26 Express
Narragansett Bay, RI
Lots A Luck
Trojan F-26 Express
