318 raw water cooling plumbing
patc
Post by patc »
Took over a project (25') and need to know how to plumb this engine for raw water cooling. It has a single pocket pump and an automotive pump also. The manifolds look to have been fed in the top front and also the bottom rear side, based on the fittings. I can't figure how to plumb it back up again. Is there anyone that would know, or is there a diagram that I can get for this application. Thanks
jav
Post by jav »
Pat,
with a circulation pump, it sounds like a fresh water cooled engine. Is that correct?
