F32 rear fuel tank replacements
zbigk
2019 Forum Supporter
Post by zbigk » Tue Nov 22, 2011 9:50 am
Hi All,
The rear fuel tanks in "Time Out" are disintgrating. I started picking up a fine white sand like substance in the water/fuel separators. So I am in process of shopping for replacement 60 gallon tanks. I am looking for drawings to provide so i can get estimates. I do have drawings for 99 gallon tank replacements but I decided not to go that route.
I sent requests for prices to the following:
http://www.sptanks.com/webdev/home.htm
http://www.amarket.com/alum.htm
http://www.custommarinefueltanks.com/
http://www.rdsaluminum.com/marine-custom.html
http://www.patriotmarinefab.net/
http://www.speedytanks.com/tank/index.html
Any advise would be appreciated.
Thanks,
ZbigK
"Time Out"
Milford, CT
1982 F32 330hp MPI Crusaders
g36
Post by g36 » Tue Nov 22, 2011 10:08 am
on my 78 f32 i had the same white sand and other internal tank corrosion once i started looking.
i replaced mine this past spring with new tanks from sptanks. i had the tanks built to the same deminisions i already had. upsized the aluminum to larger so it would bunk properly in the same tank mounts. with out any other support. had all the fittings put in the same spots. tanks went in very easily. i painted the bilge while they were out when i got done and new tanks installed i hated to cover it back over with the deck. gotta love that cockpit floor just lifting out for the exchange. i am very happy with the money i spent with sp tanks
you dont need any fancy drawings. spend a few minutes with a ruler and draw them out measure the distances for the fittings and submit it. i know if sp has any questions they will contact you. they wont start till everything they need is given. you may even ask if they still have mine from this spring
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
Location: Colonial Beach, VA- The Play Ground on The Potomac
Post by Stripermann2 » Tue Nov 22, 2011 11:05 am
This is what I have on my boat and I believe they are original as supplied to Trojan, at some point in time.
http://www.floridamarinetanks.com/
Struts and Rudders
Post by Struts and Rudders » Tue Nov 22, 2011 12:32 pm
tank builders that serve the custom and production boat markets in and around the Carolina region seem to price or quote by the gallon.
I have found quotes ranging from$ 8.00 to $9.50 per gallon for your comparitive information.
SRD
F36
Commissionpoint
Post by Commissionpoint » Tue Nov 22, 2011 2:21 pm
+1 on SD Tanks. They make a great product. Will custom build anything you want as well. Pricing is also quite competitive.
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
Commander 351 Ford (PCM)
1:1 Borg Warner
mtwolf
Post by mtwolf » Thu Dec 01, 2011 8:55 am
Just make sure they are Coast Guard approved. If something went wrong, (heaven forbid a fire,) the insurance company would have a field day.
John
1973 F-31
rossjo
Post by rossjo » Thu Dec 01, 2011 9:46 am
Ethanol is very corrosive.
Here is a position paper by the National Marine Manufacturers Association (NMMA) on Ethanol ...
"The Negative Affects of Ethanol on Recreational Boat Fuel Systems
The National Marine Manufacturers Association (NMMA) opposes the use of marine fuels that contain greater than 10% ethanol content by volume. This position is based on safety and durability concerns and supported by many well documented studies.
According to state boating registrations, there are over 12 million recreational boats in the United States. Boat builders utilize five types of materials to fabricate fuel tanks. These are aluminum, steel, cross-link polyethylene, high density polyethylene and fiberglass. For a rough estimate of today’s numbers, there are approximately four million boats that have aluminum fuel tanks; approximately seven million have steel or polyethylene tanks, and less than one million have fiberglass tanks. The data clearly indicates that the increased use of ethanol in gasoline has raised safety and durability issues for aluminum and fiberglass fuel tanks.
Aluminum Fuel Tanks
In the case of aluminum tanks, aluminum is a highly conductive metal that relies on an oxide layer for its corrosion protection properties. Low levels of ethanol, such as E10 (10%), are usually not a problem in aluminum tanks because the oxide layer provides a good measure of protection. The problem occurs when the ethanol content is increased.
There are two mechanisms that occur with ethanol. Both mechanisms are a result of the hydroscopic property of ethanol, meaning it absorbs water. The more ethanol in the fuel, the more water there will be in the fuel tank. Water not only causes the tank to corrode, it also causes the corrosion particles to clog fuel filters, fuel systems, and damage engine components. The corrosion rate can be accelerated under a number of conditions if other contaminating metals are present such as copper which may be picked up from brass fittings or as a low level contaminant in the aluminum alloy. Chloride, which is a chemical found in salt water, will also accelerate corrosion. In the long term, corrosion can perforate the aluminum to produce leaks that would cause fuel to spill into the bilge and end up in the environment. In the worse case it could cause a fire and/or explosion hazard. Boat fuel tanks are often located under the deck next to the engine where the operator might not be aware of a leak until it was too late. .
The second mechanism that can occurs with the increased use of ethanol based fuel in aluminum tanks is galvanic corrosion. Gasoline fuel is not conductive, but the presence of ethanol or ethanol and water will conduct electricity. The galvanic process that occurs to aluminum trim tabs, stern drives, shaft couplings, etc. will occur within the aluminum fuel tank. Boat builders are able to protect exterior aluminum boat equipment with sacrificial anodes known as zincs. Sacrificial anodes are not a feasible option for the interior of a fuel tank.
Fiberglass Fuel Tanks
NMMA is in the early stage of evaluating the effects that ethanol in gasoline has on fiberglass tanks. Boat U.S., the boater advocacy association, recently issue a consumer alert reporting that owners of older yachts have experienced leaking fiberglass fuel tanks. There have also been reports of heavy black deposits on the intake valves of marine engines resulting in bent push rods, pistons and valves. Some of the preliminary analysis conducted by an independent lab found the deposits to be di-iso octyl phalate, a chemical found in the resin, gel coat and filler used to make fiberglass fuel tanks.
An initial theory is that when ethanol is introduced to the fuel tank the very small ethanol molecules diffuse into pores between the resin where they dissolve the unreacted phalates. Since the phalates are in solution they are able to pass through the fuel line filters. These phalates have exceptionally high temperature stability and remain intact when the fuel evaporates in the carburetor or undergo only partial decomposition in the combustion chamber thus creating the heavy black deposits on the engine’s intake valves.
Unlike aluminum, NMMA has yet to identify the effect that ethanol in fuel has on the tanks integrity or even the root cause of dissolved phalates. The theory is that it is being caused by ethanol and we know that ethanol dissolves phalates, but more testing is currently being conducted.
Conclusion
As stated in the opening paragraph, the NMMA has serious safety and durability concerns with the incremental increase in ethanol content in gasoline motor fuel. The majority of marine engines in use today are open loop systems that are designed, engineered and calibrated at the factory to operate with fuel containing either 10% MTBE or ethanol. Changing the fuel that these engines were designed, engineered and calibrated for will negatively effect drivability, exhaust and evaporative emissions, and potentially damage the components.
While these issues are significant, the boaters have a far more serious issue. The available data indicates that aluminum and fiberglass fuel tanks and butyl rubber fuel hoses that are currently being used will fail if the ethanol content is increased to 20%. That is not an emissions issue; it is not a drivability or durability issue. It is an issue that needs to be taken far more seriously. It is a threat to the health and safety of the boaters in your state.
ref: http://www.google.com/url?sa=t&rct=j&q= ... VjRUaFK7Bw
Post by larryeddington » Thu Dec 01, 2011 10:03 am
just got my new SP Tanks for my F28 increased size from 50 gal to 75 gal and though not installed as yet sure look good.
Post by Stripermann2 » Thu Dec 01, 2011 10:45 am
Larry, or anyone else...does SP, have spec sheets or previous tank replacement drawings for specific boat models or do they start from existing tank measurements provided to them?
I would think a company like SP, in as long they have been doing this, would readily know the tank dimensions and a quote for say a Trojan F-32 or a Searay 34 sedan for example?
Post by larryeddington » Thu Dec 01, 2011 10:57 am
On the SP website they have an application that gives several designs of tanks which will tell you how many gallons the proposed tank will hold.
I measured my space and sketched it up (they have a page to show you what they need) called them and they gave me a proposal on what I wanted.
Otherwise there is not standard it is what you need and what accessories you want on the tank such as tabs, clean out port etc.
My tanks appear to be exactly as I sketched and though they are still in shrink ramp, SP says they are tested per USCG regs and a placard is affixed to that affect.
Larry
Last edited by larryeddington on Thu Dec 01, 2011 10:42 pm, edited 1 time in total.
mtwolf
Post by mtwolf » Thu Dec 01, 2011 7:14 pm
I replaced mine a few years ago. Florida Marine tanks made the replacements but put ther wrong sending units in the tanks. I ended up replacing the guages and tank senders. From what I gather they no longer make the round tanks for thr F-31. The fuel line pick up, on the back tank, was scaled shut.
Fishblues
Tanks
Post by Fishblues » Sat Dec 10, 2011 1:45 pm
Ill open up a can of worms... Just put two new Moeller tanks in my F32 and I love them. 58 gallons each.
gettaway
Post by gettaway » Sat Dec 10, 2011 11:50 pm
the plastic tanks look great, I am thinking of the same for mine when the time comes, is the opening in the center of the tank the baffle?
k9th
Post by k9th » Sun Dec 11, 2011 12:31 am
I replaced both my tanks last year with tanks made by SP. They are well made, high quality, and fit perfectly. I would highly recommend them.
Tim
"SeaDog"
1979 36' Tri-Cabin
TADTOOMUCH
Re: F32 rear fuel tank replacements
Post by TADTOOMUCH » Thu Sep 20, 2018 2:33 pm
how hard was it to get the old cylinder tanks out. mine are hard piped in and I am not sure where to or how to disconnect the pipes. Where did you start?
Boat Name: A TAD TOO MUCH
Engines: Twin Chry 360's 625 hrs original engines
