- 2019 Forum Supporter
- Location: Near Baltimorgue, where Maryland proves to the nation every day that gun control doesn't work.
Post
by P-Dogg » Fri Aug 10, 2012 11:05 pm
P-dog will you be hooking up a 3rd meter for the gen-set ?
It is done. I did not include it in the post because it would be like the movie Groundhog Day. I just showed the shore power set-up because I did it first. I figured it would be enough to encourage people who might not think that they can do it to actually try it. It is a straightforward improvement and rather easy to do, if a tad time consuming because I worked methodically, enjoyed being on the boat in the marina on a slow weeknight by myself (had that first beer watching the sunset from my bow seat -- contemplating the windlass and spotlight install), and ended-up making a few intermediate trips to Radio Shack because I didn't plan well enough.
One note of caution: These are 50 amp-rated meters. The generators on tris are 6.5 Kw, which equals 54 amps at 120v. I have no idea what the meter would do if "overloaded" (it is only a signal input that is out of range, not a power input). I figured that if I was asking 50 amps from my generator, that would be enough.
jefflaw35
Post
by jefflaw35 » Fri Aug 10, 2012 11:08 pm
did you add any inline fuse? reguardless I like the work and idea....
Post
by RWS » Sat Aug 11, 2012 7:47 am
nice stuff
well executed !
now if we could just source a reasonably priced replacement set of LED polarity indicators for those of us whose factory units are no longer functioning, we'd be all set.
Twin Yanmar 315 Turbodiesels
Trojan International Website:
http://trojanboat.com/
aaronbocknek
Post
by aaronbocknek » Sun Aug 12, 2012 5:06 am
RWS wrote:nice stuff
well executed !
+++++1 on that one buddy.
Post
by Big D » Sun Aug 12, 2012 11:57 am
P-Dogg wrote:....One beer and two hours later....Note the star lock-washer between the panel and the crimp terminal....The orange wires (right) and white wires (left) are twisted from the coil to the meter so that they don't pick-up any stray induced current from the conductors that they run adjacent to....Time for another beer....
Very good post. These points you touched on are critical in a proper and SAFE install. The only problem I would have is just the "one beer" in "two hours"
Great job, bet a few guys will consider this one.
Here's a thought that I'm thinking would be handy and considering adding as well; bought a didgital LED frequency meter several years ago to install in the panel and monitor marina and generator output. It's an especially good tool to ensure your genny for example is set up properly and delivering proper rpm at a given load. I haven't installed it yet but thinking it would be a neat project to tinker with....not a critical reading as voltage will tell you a lot but I like bells and whistles!
1969 36 ft wooden beauty with big blue 440s
- 2019 Gold Support
Post
by prowlersfish » Sun Aug 19, 2012 10:49 pm
I ordered some myself
TROJAN F36 Conv.
2009 TROJAN RENDEZVOUS
aweimer
Post
by aweimer » Fri Sep 14, 2012 3:54 pm
Thank you for this!
Ordered mine today, hoping to do this next weekend if they arrive over the next week. VERY nice job!
Post
by larryeddington » Sat Aug 25, 2018 10:50 am
Hi P-dog,
I have the meters but due to family first things I have not got time to install them. There were pictures you posted but gone now can you re- post them on here as Bob has fixed the picture posting issuer. I wan to make the install and include the Genny. I have a much larger sampler that will actually look at each battery even while starting, can sample 1000 amps.
Captrichc
- 2019 Gold Support
Post
by Captrichc » Fri Sep 14, 2018 12:39 am
P-Dogg wrote: ↑Fri Aug 10, 2012 4:02 pm
My 1985 tricabin left the factory without any ammeters installed, something I find incredulous, since I think that there should be some way of indicating how much power you are drawing other than blown breaker method. Wanting to know how much load I as actually drawing from my shore power lines (and my generator as well, when it is in use), I undertook the minor task of replacing the analog volt meters in my panel with digital LCD units that measure and display volts and amps simultaneously. For those of you who may be tempted to do the same, here is my story.
From Ebay, I bought 5 of these meters for $75:
http://www.ebay.com/itm/300722663809?ss ... .jpg[/img]
1974 f32 Sedan
Twin 233 Mercruisers
