Good Windlass issue
zbigk
Good Windlass issue
Post by zbigk »
Hi everyone,
I was using my windlass and once it dispatched 30 feet of line, it stopped. No up or down. Motor is not eventrying. So i assumed it tripped a breaker. I went to the panel (under lower pilot station) and did not find a breaker. So now i assume there is an in line fuse somewhere. I took a quick look around & did not find it anywhere. Any ideas where the fuse or a breaker might be located? Later this weekend i will unscrew the DC panel and see if it's hiding behind there.
Boat is a 1982 F32 Trojan.
Any suggestions are appreciated.
Thanks,
ZbigK
"Time Out"
Milford, CT
1982 F32 330hp MPI Crusaders
Allen Sr
Post by Allen Sr »
Mine is wired directly to the batteries.
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
gettaway
Post by gettaway »
if you pull up the center hatch closest to the stairs, right below the supporting edge, there is a big inline buss fuse, in a ceramic holder.
1984 Silverton 37C
Silver Lining
Scott
PHOPKINS1964
Windlass
Post by PHOPKINS1964 »
Had the same problem, it was the 50amp breaker in the eginge compartment
DAVIDLOFLAND
2024 Gold Support
2024 Gold Support
Post by DAVIDLOFLAND »
My Quick vertical windlass (motor below deck) did the same thing. Turned out it was leaking at the deck, and filled the motor housing with water. As a temp repair, I took it appart and cleaned the brushes, then drilled a couple of holes in the motor end cap, to let any new water drain out.
I never like the way thing worked anyway (didn't always feed the line and chain without assistance), so am replacing with a horizontal (above deck)windlass next spring.
Yanmar 6BY3-260's
The Good Windlass set-up, usually has the breakers, power and ground coming together in a bracket located in the anchor locker. I have replaced my motor, top assembly with gears and line with updated parts from Good.
It's a pretty simple set-up and not hard to diagnose and repair.
Give them a call, best yet to email Tom and have him call you back. Quick answers and delivery...once you get to speak with him. :wink:
http://www.goodwindlass.com/
zbigk
Post by zbigk »
Gents,
thanks for the replys. I'll get to the boat this weekend to see if i can find the breaker, or fuse. i'll start in the anchor locker & work my way back.
Thanks again.
ZbigK
"Time Out"
Milford, CT
