Page 2 of 4
Re: F-26 Deck Repair
Posted: Tue Mar 26, 2013 8:54 pm
by MattSC
Thanks guys
Paul wrote:Wow Matt. looks great! Good time to add a windlass.
Paul, do you have a windlass on your F-26? That's funny, I was thinking the same thing and also adding a pulpit. Not sure what type of windlass to go with though, there are so many to chose from and I don't want to make a snap decision, choose the wrong one and regret it
Posted: Wed Mar 27, 2013 12:41 pm
by Paul
Yes Matt, I have a 400 Horizon by Simpson Lawrence and instead of a pulpit, I have a self launching (pivoting) bow roller. I spend allot of time on the hook and have found this thing to be priceless. In a tight anchorage area its better to be at the helm and in control of the boat when your anchor leaves the bottom than on the bow yanking on a rope, especially on a windy day.
I've been using this unit most summer weekends since I installed it in 2001 and other than greasing it once, have had to replace the gypsy (plastic) once. It's very reliable however if I was to replace it I think that I'd look for one with a free fall option.
I'll dig up a picture of it when I get home and post it for you to see.
Posted: Wed Mar 27, 2013 8:52 pm
by MattSC
Thank you Paul, that would be great. I do like the idea of being able to control it from the helm, I will take a look at that model.
Matt
Posted: Wed Mar 27, 2013 10:10 pm
by Paul
Here it is.
Posted: Fri Mar 29, 2013 6:19 pm
by MattSC
Hi Paul,
Thanks for the photo, it's going to help quite a bit. Your deck looks to be in great shape
I have a couple of questions regarding the windlass:
Did you move your bow cleat when you installed the Windlass, and if so is it off center just a bit so it won't catch the anchor line when it's lowered?
I see you also have your original anchor setup as well, how much anchor line and chain do you have for both? and is the anchor locker pretty tight with everything?
Thanks again,
Matt
Posted: Fri Mar 29, 2013 10:02 pm
by Paul
Hi Matt,
I moved the cleat forward and installed the windlass where the cleat was originally. The cleat is installed on center and I've never had the rope or chain get caught on it. I think it's because the rear roller on the bow roller assembly tips up when the anchor is deployed and keeps the rode away from the cleat.
I have 200' of rope with 15' of chain on the windlass and 100' of rope with 10' of chain on the original anchor. As for the anchor locker, I added a small dividing wall to the right of the access door creating a three sided compartment between the hull and bulkhead. The wall runs fore & aft, is about 12'' high and is cut to shape so it will fit vertically. Its epoxied into place and is open a bit at the bottom for drainage. Its also painted with bilge paint so that a damp rope won't rot the bulkhead. This basically splits the anchor locker into a section for each anchor and I've never had the ropes get crossed up.
Keeping the original anchor in place can be a handy thing. I use it occasionally for a Bahamian rig or when a stern anchor is necessary. You'll also notice that there are a few other items that went along with this installation. 1st is the safety lanyard that is attached to the deck at one end and latched to the chain at the other to prevent an accidental deployment of the anchor. Next are the snaps screwed to the deck surrounding the windlass. These are for the Sunbrella windlass cover which is in place when the boat is not in use. Lastly, you'll notice a deck plate installed next to the windlass. Beneath it is a coil hose and nozzle that I (or my wife) use as a wash down for when the anchor comes up dirty.
Hope this helps
Posted: Wed Apr 03, 2013 8:07 pm
by P-Dogg
That is a huge amount of work! Looks good so far. What are you planning to use for a non-slip coating?
Posted: Wed Apr 03, 2013 9:21 pm
by MattSC
Paul wrote:Hi Matt,
Hope this helps
Thank you Paul, you've been a big help. It looks like I'm going to add it to the list, it just keeps growing
One of my concerns was the rope locker, as I usually rinse and leave my anchor line out to dry before I store it. I like the idea of the windlass cover.
P-Dogg wrote:That is a huge amount of work! Looks good so far. What are you planning to use for a non-slip coating?
Thanks P-Dogg, It's been an interesting project and I have learned a lot since we started. I'm going the have the topsides re-gelcoated and a new nonskid gelcoat pattern applied (it will be rolled on). I am really looking forward to that
Posted: Sat Jun 01, 2013 9:36 pm
by MattSC
Posted: Sat Jun 01, 2013 9:58 pm
Thats a lot of work . But it looks like its coming around
Posted: Thu Jun 06, 2013 9:43 pm
by wolfnnj
Wow that's a LOT of work and its looking great!
Posted: Sat Sep 21, 2013 10:13 pm
by MattSC
Posted: Sun Sep 22, 2013 1:29 am
by 32pacemaker
that looks fantastic Matt I am so jealous!!!!!!!!!!!! long time coming , that f26 looks like new.
Posted: Sun Sep 22, 2013 3:08 am
by aaronbocknek
g'day matt, she looks amazing. before i head to work i wanted to ask who did your rechroming? i've got some helm hardware (shifter covers/throttle covers) that are pitted and i'd love to have rechromed over the winter. i have been able to polish most of it away using simichrome polish, but, it's just not to my satisfaction. i will check in when i get to boston tonight, or providence tomorrow.
aaron
Posted: Mon Sep 23, 2013 11:11 am
by lawyerdave71
WOW WHAT A MASSIVE PROJECT - GOOD LUCK
