Dual Station F32 Flybridge removed / installed, problems
- Away On Busine$$
Can't start either engine from flybridge, engine warning bussers go off on bridge when I shut down from lower station. Engine warning buzzers sometimes go off at lower station when I start engines. Any ideas out there. 318s.
Re: Dual Station F32 Flybridge removed / installed, problems
Is the neutral safety function (switches) at the helms (shifters) or transmittions? If at shifters, make sure the switches are hooked up.
Nuetral saftey switches on the gears... if the upper helms worked before, clearly this is a wiring problem. Did you mark all the wires beofre and then confirm their location putting them back in? Did you perhaps touch any live wires to a ground and pop a fuse?
