Hi guys,
I need to replace the shower curtain on our F32. Shower curtain is on a ceiling track in the head. I have not had any luck finding a replacement. Is the answer replacing the ceiling track?
Any advice?
Thanks,
1982 F32 Shower curtain replacement
ZbigK
"Time Out"
Milford, CT
1982 F32 330hp MPI Crusaders
"Time Out"
Milford, CT
- ready123
Re: 1982 F32 Shower curtain replacement
Have you looked around this site?
http://www.shop.curtaintrax.com/main.sc
Any standard shower curtain should work. You'll need to trim the bottom to the right length. Can you post a photo of your existing hangers?
if is like my f28, it has little rollers that run in the track.
- aaronbocknek
actually your best bet is to keep the track and maybe replace the hardware. also, many rv stores carry 'right sized' shower curtains. if the 'two wheel carriers' are a little nasty, again, an rv store can supply them along with the I beam hardware.
here is a link for the two wheel carriers. i replaced mine on ENTERPRISE in the spring for the tub/shower. any shower curtain can work, and, as suggested, just cut the bottom off to make it fit properly.
here is a link for the carriers. hope this helps.
aaron
http://www.makariosrv.com/two-wheel-car ... hook-a109/
aaron
those rollers look exactly what mine has other than being stainless, they should work fine.
- ready123
My prior link was broken, try this one:
http://www.curtain-tracks.com/hardware/ ... track.html
Thank you all for the responses. The 2-wheel carrier was exactly what I was looking for.
ZbigK
"Time Out"
Milford, CT
"Time Out"
Milford, CT
