ac install
Posted: Thu Sep 29, 2016 8:40 pm
by billb
I was thinking of installing a new ac unit in my 79 f32. I was wondering where the best location would be to set the unit.
would under the rear dinette seat work?
thanks.
Re: ac install
Posted: Fri Sep 30, 2016 12:35 am
by captainmaniac
You can put it there, but not the best location. Mine is under the forward dinette seat. The biggest problems are that the ducting takes up most of the starboard hanging locker, and I only have vents on top / front / aft side of that hanging locker, so it is really only effective at cooling the lower cabin. The cool air just doesn't really make it up to the Salon (even with fans pushing it there). Lets face it - the F32 Salon is essentially a greenhouse with all that glass. Also I lose the storage space of the drawers that would otherwise be under the forward seat.
Some others on the forum have setups with the vents in the salon, so the salon area gets cooled and the cool air falls down to the lower cabin, probably giving better coverage. I know I have seen the salon ducts in some pictures, but not sure where the AC unit sits, and how they have run the ducting. Also need to be careful about putting the AC unit in the engine compartment, as I am not sure it fully complies with the rules around being 'ignition protected'.
I had considered moving mine to the area under the lower station (where my water heater is now), but decided that with the amount of moisture generated with the condensation from the AC, I didn't really want that near my main electrical panel!
Re: ac install
Posted: Fri Sep 30, 2016 8:11 am
by Stripermann2
My 16K unit is under my rear settee seat. I have it running to a main register in the salon, the sette wall and into the starboard vbirth wall. The ducting runs through the upper most corner of the starboard hanging closet so it hardly affects any storage.
You do lose the drawers on that side of the dinette. I made a grill which takes place of the drawer fronts.
System works well. However, as Captainmaniac mentioned, the salon is a green house. We have curtains to help keep salon cool.
Re: ac install
Posted: Fri Sep 30, 2016 8:49 am
by gitchisum
My unit is under the back deck, with blowers in the salon and anchor locker ( venting for salon and berth) My assumption is this was a factory install as documentation shows it was ordered with A/C. This is on a 1988
- AC Unit.JPG (128.34 KiB) Viewed 6401 times
Re: ac install
Posted: Fri Sep 30, 2016 11:23 am
by Stripermann2
Yep, you have the split system. The self contained units take up some real-estate.
Re: ac install
Posted: Fri Sep 30, 2016 4:31 pm
by K4282
Re: ac install
Posted: Fri Sep 30, 2016 6:38 pm
by g36
Come on to tennessee in the summer when it's mid 90's plus for over 100 days this summer and mid 80's at ni gh t and humidity in the 70's and try getting by without ac. This is the first weekend we will be Able to get a decent nights sleep with no ac. Fall is finally getting close.
Re: ac install
Posted: Fri Sep 30, 2016 9:17 pm
AC is a must for us. in fact I am adding a 3rd AC for a total of 30,500 btu
