Modern engine upgrades?
I still love my 1980 F28, but...maintaining these thirsty 305s gets me to wonder about the sense or even the possibility of replacing them with newer motors. Something like a pair of late model automotive 4.3l injected V6s for example. I'm sure I could get even more than my existing 228 hp from a newer V6 but not sure how to find out about joining up with the velvet drives and exhaust manifolds etc. Anyone have any recommendations or warnings?
Thanks,
Steve Barlow
Thanks,
Steve Barlow
1980 F28 flybridge
2x 305 Mercruiser
2x 305 Mercruiser
- The Dog House
Re: Modern engine upgrades?
Fuel injected Chevy 350s would use less fuel and be a direct replacement. The Volvo 5.7GSi in my last boat burned 6 gph at 3000 rpm.
Former boat: 1971 Trojan F26
If you want to up grade to a 4.3 EFI go with a marine 4.3 EFI or 305/350 EFI . The automotive EFI where not calibrated form marine used in some cases different sensors used or not used in marine . Its been done and they never run right .wetbuoy wrote:I still love my 1980 F28, but...maintaining these thirsty 305s gets me to wonder about the sense or even the possibility of replacing them with newer motors. Something like a pair of late model automotive 4.3l injected V6s for example. I'm sure I could get even more than my existing 228 hp from a newer V6 but not sure how to find out about joining up with the velvet drives and exhaust manifolds etc. Anyone have any recommendations or warnings?
Thanks,
Steve Barlow
- P-Dogg
And any new engine sold as complete requires emission controls. Unless Trump already fired that branch of the EPA......
Don't wanna derail, but jut have to say........ OOOOOO -- the first Trump shot I think I have seen on the forum yet! I was expecting one <bleep> of a firestorm leading up to the election, but eventually figured people were just too scared to say anything! (or the Moderator deleted a hundred posts a day???)P-Dogg wrote:And any new engine sold as complete requires emission controls. Unless Trump already fired that branch of the EPA......
- P-Dogg
I just tell the truth man.....
Good riddance EPA in my opinion.
Lets not start the fights now... or at least take it to Pontifications!larryeddington wrote:Good riddance EPA in my opinion.
- Moderator
captainmaniac wrote:Don't wanna derail, but jut have to say........ OOOOOO -- the first Trump shot I think I have seen on the forum yet! I was expecting one <bleep> of a firestorm leading up to the election, but eventually figured people were just too scared to say anything! (or the Moderator deleted a hundred posts a day???)P-Dogg wrote:And any new engine sold as complete requires emission controls. Unless Trump already fired that branch of the EPA......
Only a few hundred . Honestly it has not been a issue and hopefully will stay that way . Now when it comes to the sneaker spammers that's a different story . Enough said back to BOATING !!
Moderator
Forum Moderator
TrojanBoats.Net
Trojan Boater
Forum Moderator
TrojanBoats.Net
Trojan Boater
Thanks for the inputs everybody. The 350s are out for sure. I thought of 4.3 only because a well known V6 might be more saleable in today's markets. Good point about EPA regulations though I likely wouldn't buy new ones. Will check the engine vendors for now. Thanks all, Captain Steve
1980 F28 flybridge
2x 305 Mercruiser
2x 305 Mercruiser
Why are 350s out ? they have the same foot print . As far as fuel burn at the same speed the 4.3 /5.0 (305)/5.7 (350) will all burn about the same amount of fuel .wetbuoy wrote:Thanks for the inputs everybody. The 350s are out for sure. I thought of 4.3 only because a well known V6 might be more saleable in today's markets. Good point about EPA regulations though I likely wouldn't buy new ones. Will check the engine vendors for now. Thanks all, Captain Steve
Lets say your single engine boat burns 10 gals a hour at 20 knots with a 4.3 the same boat with a 5.7 will burn about the same at 20 knots . There could be a slight difference ether way but it won't be much . This is assuming all have the same fuel system
I have done about all the research on engines that can be done on a f32 and found the pcm zr6 which is a 6.0, 390 hp 490 ft lb combo at $12,000.00 with transmissions to be a perfect setup. It will run all out at 5200 rpm full gear and 300 gal of fuel 37 mph gps. I do not have fuel meters so I cannot tell you a true fuel consumption bu I ca tell you that we go out and ride all weekend on 50 gal, we try to run under 3000 rpm.
How many hours/miles do you get out of the 50 gal ?
I think if you put V6's in the boat your resale value will really suffer! I have a F28 now and the previous owner replaced the old Chrysler 318's with Crusaders 350's and they perform well
Spanish Fort, Al
Looking for 33 International
Spanish Fort, Al
