Halogen to LED
Halogen to LED
The boat is a 2000 Trojan 400 Express with 12 original Hera ER 1 Halogen recessed lighting throughout the cabin. I want to replace the lights with LED's but I've searched for the transformer, behind the electrical panel, behind cupboard panels, lower storage area but no results. Any suggestions where I can look for the lighting transformer?
Re: Halogen to LED
Not sure if it even has one . Have you checked with carver ?
Re: Halogen to LED
I should have said 'regulator' instead of transformer, which wouldn't be necessary. It may not use a regulator either. I'll check with Carver, thanks.
Re: Halogen to LED
My carver 405 has the same hera halogens. There is no transformer or regulator they are wired to 12v circuit I'm pretty sure yours is too. I replaced all mine with leds If the fixtures are in good shape just replace the bulbs with something like this ive had these installed about 3yrs now for $2.88 a fixture just plug them in. Bulbs have a wide dc spec so they will handle various dc voltages no problem.
https://www.amazon.com/gp/aw/d/B001GH0F ... 274ZEF9XYZ
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
