1989 12 Meter MY 6-71's
Carried Away
Post by Carried Away »
Does anyone know the location of the aft shower pump??? I found the forward shower pump (clogged full of hair) but cannot find the aft shower?????
2024 Gold Support
2024 Gold Support
Re: 1989 12 Meter MY 6-71's
Welcome to the forum . I wish I could tell you where it is . You could try tracing the drain hose . If no luck and no answers try calling Bob at Beacon marine
Infront of the door to head/shower pull carpet back and there is a floor panel remove it and the pump should be visible. You may need to unscrew the panel.
(Under floor near water tank center)
Carried Away
Thank you for the welcome!! And thank you very much for the location!!!!!!!!!
