flybridge wiring and removing of possible shorts.
Re: flybridge wiring and removing of possible shorts.
i believe they are original ac gauges. boat is 1979 f30 flying bridge. i did read that post before i didnt know if a dual sender would still run the lower port side oil gauge if it was unhooked upstairs
If they are AC gauges then the senders are the same BUT the Gauges are different and made to work in pairs so if only is used it would be off . How much and what way I don't have a clue / Bob may know .
thanks prowler. i was just wondering why it would matter. the gauges are only powered on the FB when the key is on right? so if the power was disconnected to the FB wouldn't it be the same as having the key off?
No , the gauges are still wired to the sender and made to work with both gauges wired up . Also when you power up one station the other station gauges get powered up through the ignition circuit . By unplugging the upper station you have taken the gauges out of the circuit and changed the restance .hammerhead wrote: ↑Sun Aug 05, 2018 10:01 am thanks prowler. i was just wondering why it would matter. the gauges are only powered on the FB when the key is on right? so if the power was disconnected to the FB wouldn't it be the same as having the key off?
thank you so much for the info. the dual sender we have now has the 2 spade connectors that plug to the top. 1 power and 1 to the sender. if i switch to a single sender where does the power wire go? i can still use the gauges right or do they make gauges different for dual and single?
Please re-read all the above . If you do have AC gauges It The gauges made for dual helms not the sender !
Why not just fix the wiring that's burnt ?
https://www.trojanboats.net/zencart/ind ... ts_id=1464
http://www.trojanboats.net/trojan-boat- ... nders.html
Gauges MUST match the sender . AC need to have a AC spec sender and be the right Gauge for dual helm or the right one for single helm .OTHER brands in most cases need the right sender for single or for dual helm and they must match the gauge .
we planed on it but i don't think we will get to it until the fall.prowlersfish wrote: ↑Sun Aug 05, 2018 9:22 pm Please re-read all the above . If you do have AC gauges It The gauges made for dual helms not the sender !
thanks again. i did reread the page. sorry this thing has my head spinning. i did read somewhere that senders from auto parts store wont work. is that correct? do you know where i can find a wiring diagram for the FB? the harness is totally melted and hard to tell where the wires go now.
You can get the diagrams from Bob at beacon marine . He can put together a complete manual for your boat . And no you can't use the auto part senders with you gauges .
