When I throttle down to idle from the bridge the lower helm does not bottom out with the upper helm. Cable at carb. is adjusted. Any adjustment between helms?
Tony
Throttle cable between helms
Re: Throttle cable between helms
Yes , the cable can be adjusted on both ends
Where would I find the adjustment points?
At the end of the cable at the control
