Hydraulic steering
2024 Gold Support
2024 Gold Support
Re: Hydraulic steering
WayWeGo wrote: Wed Jan 23, 2019 4:18 pm I think the steering ram I got out of another F-36 to install in mine only has 7" of travel. You need to make sure that the hydraulic cylinder stops the rudder travel before any rudder stops or other restrictions, or your cylinder will not last very long.
Mine has indeed 9" of travel , Yours may have shorter tiller arms As I believe the F32 also has .
Captrichc
Post by Captrichc »
Measured the new fuel tanks for the craddles. Ordered the marine ply wood and started measuring for the floor.
1974 f32 Sedan
Twin 233 Mercruisers
Captrichc
Post by Captrichc »
davidguetta402 wrote: Mon Jan 28, 2019 6:34 am use the same hydraulic assist technology as standard systems, but the hydraulic pressure comes from a pump driven by an electric motor instead of a drive belt at the engine....!
_____________________
Wasnt going to do drive assist. Anyone else go this route?
1974 f32 Sedan
DAVIDLOFLAND
2024 Gold Support
2024 Gold Support
Post by DAVIDLOFLAND »
Instant Fun has SeaStar (Teleflex) hydraulic steering at 2 helms. No electric assist or hydraulic assist from the engines, just the manual pump at each helm. Steers like butter with one finger in the wheel. In fact you can spin the wheel while underway.
Yanmar 6BY3-260's
DAVIDLOFLAND
2024 Gold Support
2024 Gold Support
Also, the Garmin autopilot SmartPump tied right into the steering system with no modifications. I did add a rudder angle indicator to make the autopilot pump last longer. The rudder angle indicator also proved quite handy at the helm. Who'd a thunk?
Yanmar 6BY3-260's
