I used 5200 below water and boat life above.prowlersfish wrote: ↑Mon Apr 01, 2019 10:49 pmIf this below the water line do not use silicone . Use something like 4200 or 5200 .
Cappy's f32 rehab
Re: Cappy's f32 rehab
1974 f32 Sedan
Twin 233 Mercruisers
Started the hatch for the deck. Cut out the plywood and the trim is cut.
1974 f32 Sedan
Hatch is glassed and gelcoated. Will trim the glass and put aluminum trim on it in the AM. I have 1 final coat of gelcoat to put on the deck and it will be complete.
1974 f32 Sedan
Hey Cappy lets see some more pictures
Here is the hatch.
- 20190407_153248.jpg (78.01 KiB) Viewed 11757 times
1974 f32 Sedan
Thanks WayweGo. I have 2 handles to add then onto the boat. Once its on the boat oat i can uncover her amd start cleaning and running the electronics.
1974 f32 Sedan
Just picked up the generator. Its amazing. Thank you so much Bret!!!
1974 f32 Sedan
Canvas are done. And rubber gasket is done on hatch. Pickup and exhaust are drilled and set for genny. Will do the zinks and put props on today. Add the transducer for the new simrad system. Bottom is painted. And i figured out the starter issue.
1974 f32 Sedan
- WayWeGo
Rich, you are making great progress and I am especially glad to hear you got your starter working correctly.
Yes me too. And thanks for the kind words. Moving along as best as i can. Finished 1 of the engine hatches today. Im just checking off as i go.
1974 f32 Sedan
Uncovered the boat yesterday. Not happy with the bow at all. Softer then i remember. That i will have to keep an eye on. Will definitely have to cut it all out and recore this winter. Im hoping it doesnt effect my season.
1974 f32 Sedan
Engine hatches complete. Transducer mounted. And props are put back on. Very happy at the moment. Will get some new pics this week.
1974 f32 Sedan
