Putting new screw cover “foam” in at windshield and side glass. Part number available, anyone? Or best resource to find it? There was no existing gasket on the boat. The previous non - caretakers used residential a/c window unit foam to collect the water.
Thanks in advance.
1996 390 Windshield Screw Cover
Re: 1996 390 Windshield Screw Cover
Hi, Good to hear from you. I know exactly what you're referring to and although I had previously located a source, darned if I can find where I "carefully" filed it away. These people here https://www.mcmaster.com/ might be able to point you in the right direction. They have some foam type covering but not what I think you're looking for. Prowlerfish might be helpful. If I find what I'm looking for I will post it here. best of luck with your 390.
Rick
Rick
Hi,
The foam that I was referring to in the above post is found right here at our own Trojan Online Store. Please go over to the store and you'll find it.
Tap on Trojan Parts under the Categories Heading. Then tap on International Series in the drop down menu under International Series. Then in the Gold Covered Folders tap on Gaskets/Channel. Scroll down 8 photos to DECK FOAM.
Trojaniki, this may not be what you require but it is definitely what I was remembering. I have always figured this foam would fit on my '94 370 in exactly the same location you are referring to.
Please let us know what you find out if you phone or email Beacon
Rick
Rick
Rick - thanks a ton.
