Winterizing 454 crusader
New to winterizing engines and just want to double check with all of you. I have a closed cooling system and am looking to winterize the raw water side by pulling the water pump hose and attaching it to a five gallon bucket of anti freeze mixed at a 50/50 ratio. Do you think this is enough coolant throught the system? Does anyone drain the heat exchanger first??? I was hoping to just pull the hose off the sea cock and push all the water out that way. Think five gallons is enough????
I would suggest using the non toxic pre mixed anti freeze my model 270 crusaders take 3 gallons each
TIKI III
1985 F32
270 Crusaders
Wet and happy
1985 F32
270 Crusaders
Wet and happy
I drain first. One plug on the bottom center of the block each side, and 3 plugs on each side of the exhausts. Then I put all the plugs back in and remote the raw water hose from the through hull and insert a large 1Gal funnel. I start the engine and pour in about 5 gallons. I think at three, its pretty good, but the extra two are cheap insurance that it filled up with the pink stuff.
Don't forget to drain your fresh water system and pump through a gallon of the pink anti-freeze there too. Last think, a 1/2 gal in the head and pump it out.
Current Fleet:
2000 Carver 450 Voyager
1994 Scout 15'
2005 Caribe LCX9 dingy
1981 16' Hobicat
1994 Scout 15'
1981 16' Hobicat
- Stripermann2
Winterizing...hmmm, not familiar with that word.
I have flushers on my strainers. After I drain the blocks and shut off the seacocks, I can flip the lever on the strainer lid, hook up a hose and suck the antifreeze from the jugs as the engine is running. Works well with no hoses to undo.
