Emergency Start???
ScurvyDog
Emergency Start???
Post by ScurvyDog »
Just bought a F32 and was wondering what the switch labeled Emergency Start did. I have no manual and am scared to push it. What does it do over the normal start buttons?
willietrojan
Post by willietrojan »
I think that will let you use the battery from one engine to other, incase
one battery is weak and does not have enough power.
ScurvyDog
Post by ScurvyDog »
Thx willie, kinda what I thought it did. Simular if I turned the battery switches to combine all banks.
pcbbutch
Post by pcbbutch »
Hello, I also just bought a 79 F-32. Willie is right on the start its just like putting jumper cables on from one battery to the other.
Good Luck,
Butch
butch79/F-32
Apple
Post by Apple »
Just a thought... The switch doesn't do anything if the solenoid that it's connected to is bad.
ScurvyDog
Post by ScurvyDog »
Thx for the replies guys. It's kinda what I figured the switch to do. Haven't tried it yet but by the sounds of it should test it to make sure the solenoid it working before needing it!!! Luckly I do have a house bank of batteries!
