have original two tanks on 1981 f-32
if tanks have to be replaced what has to be done??
this model has water tank in between with air condirioner unit on top.
does back cockpit floor have to be cut away??
gas tanks f-32
gas tanks f-32
The cockpit sole on my 1977 F-32 is held in by 8 bolts. You don't even have to remove the bridge ladder. I replaced my 60 gallon tanks with 80s'. Be sure to check the fill hoses for rot.
Lakeguy
Lakeguy
gas tanks f-32
From 1977 on up the cockpit sole is the same. Prior 1977 they all had a teak sole over plywood.
Lakeguy
Lakeguy
