need help
kickervr15s@aol.com
need help
Post by kickervr15s@aol.com »
i have 1976 f25 express trojan boat just bought and bracket holding the drive shaft up with the 4 bolts has on it #13-057 can anyone tell me if that assembly with the cutlass bearing in it is suppose to be curved or straight and my rudder rod is bent is the rod replaceable or can it be bent back
one other thing my prop is bent its a 14rh10 nibral any ideas of cost of new one or any one that can fix them
Your prop should be fixable at any good prop shop , sounds like you may need a new strut and a new rudder , can you post a photo or 2
kickervr15s@aol.com
ill get some pics and post them
k9th
Post by k9th »
Welcome to the forum. Pics will always help solve problems.
Tim
"SeaDog"
1979 36' Tri-Cabin
larglo
Post by larglo »
kicker,
I have a 1980 F25 HT Express, what model is yours? I saw the bottom of my boat when I bought it, but never have since putting it into the water, so can't help you with you problem, sorry to say.
But as they say, pictures will help a lot. Put some of topside too, if you can, I would love to see them.
Welcome to the forum also.
Larry
Larry - 1980 F25 HT
"Lady G"
Mt. Juliet, TN
Call Bob, here at Beacon Marine Supply. He just did a complete replacement on an F30 a few weeks ago. Give him your strut numbers.
There were also a couple threads on props for sale here on the board recently.
kickervr15s@aol.com
pics
i have pics but cant post them
If you want, send them to me and I'll post them for you. My address is under my name.
kickervr15s@aol.com
will send them
What happend here? Everything's bent...hopefully Bob can get you back on track. Looks from the date on the rudder that it's been replaced before too.
kickervr15s@aol.com
nothing like driving it a mile like that and boat filling up with water and not much steering
Last edited by kickervr15s@aol.com on Wed Jul 21, 2010 7:21 pm, edited 1 time in total.
kickervr15s@aol.com
it would be nice to get some used ones
I could also be wrong...but it appears that the rudder blade was modified to be larger and that is not how it came from the factory. Someone else may know better.
kickervr15s@aol.com
dont they say bigger is better
kickervr15s@aol.com wrote:nothing like driving it a mile like that and boat filling up with water and not much steering
Been There done that . how bad was the hull ?
